Instron, a leading provider of testing equipment designed to evaluate the mechanical properties of materials and components, offers an easy solution designed specifically to overcome the problem of premature failure for industrial textile fibres – including Aramid and UHMwPE.
英斯特朗,全球领先的材料和构件物性测试试验机制造商,针对目前工业纺织品纤维(包括芳香族聚酰酩和超高分子量聚乙烯)过早失效这一业界困扰问题,推出气动细绳和纱线夹具,提供更便捷优化的解决方案。
Instron Pneumatic Cord and Yarn Grips (2714-04x), which test up to 2 kN, are designed with interchangeable clamping blocks that accommodate fibers or yarns made from conventional fibers or newly developed high-performance fibers. This cost-effective new feature allows customers to utilize the same grip body as the common actuator and carrier for a range of application-specific clamping blocks. Whereas before the addition of the interchangeable clamping blocks, it was necessary for a lab to purchase a full set of grips, with grip bodies, grip faces, and single purpose capstans.
英斯特朗气动细绳和纱线夹具(2714-04x),载荷可达2kN, 此可互换的夹块设计适用于由常规纤维或新开发的高性能纤维制作的纤维或纱线。此极具性价比的设计使用户可直接使用同一套夹具体,并根据具体的应用要求来更换相应夹块。基于此项新增的可互换夹块功能,用户的试验室将有必要购置全套系的夹具,包括夹具,夹面和单用途绞盘。
Aramid and UHMwPE are synthetically prepared fibres that are stronger per weight than steel. However when tested with a traditional side acting grip, they are likely to exhibit internal slippage in the jaw, where one or more fiber is slipping past the others. The fibres are also likely to fail where stress is concentrated at the jaw faces. This kind of challenge is much harder to detect and can lead to low maximum strengths and/or inaccurate results.
芳香族聚酰酩和超高分子量聚乙烯都是合成纤维,其单位重量高于钢铁。当使用传统平推夹具进行测试时,夹面可能会内部滑动,此时,纤维就会相继滑动。而应力集中的夹面上,纤维也有可能掉落。它将使检测变得更困难而成为我们的挑战,并且导致得出最大强度值偏低和/或不准确的结果。
The Pneumatic Cord and Yarn Grips incorporate a capstan design that evenly distributes the gripping force over the curved surface of an involute specially designed to maximize breaking load. The capstan provides support for the specimen, making the transition from the free-stressed length of specimen to the rigidly clamped portion gradually rather than abruptly, thus minimizing breakage of the specimen adjacent to the jaw face. The capstan also incorporates a smooth guide horn, which assists in rapid specimen loading and prevents damage to individual fibers during specimen insertion. This allows for greater failure loads to be recorded.
此气动细绳和纱线夹具结合绞盘的设计,均匀地使夹持力分布在锯齿表面,此渐开线的特别设计可使断裂载荷达到最大值。 该绞盘为试样提供支持,可使试样承受的的自由应力逐渐而非突然地过渡,因此可减小试样靠近夹面时所产生的断裂。该绞盘还有一个光滑的导角,有助于试样的快速加载,防止试样装载过程中损坏单根纤维束。使其可记录更大的断裂载荷。
Additionally, the clamping mechanism can be activated automatically and through a footswitch to allow for two-handed specimen insertion and hands-free grip operation; this enables the operator to hold the specimen with both hands for easy loading.
此外,该锁紧装置可自动通过踏脚开关激活,可双手试样插入和免手动夹具操作;从而方便试验操作员使用双手握住试样,以便于装载。
Pneumatic Cord and Yarn Grips provide selectable clamping force to accommodate different materials and excellent follow up action that compensates for decay of the holding force due to specimen creep.
该气动细绳和纱线夹具提供可选的夹持力,以适应不同的材料和良好地跟进补偿对因试样蠕变而造成的夹持力衰减。
关于英斯特朗:
英斯特朗(INSTRON )是全球领先的材料和构件物性测试试验机制造商,美国五百强公司ITW集团旗下品牌,从基本的软组织到先进的高强度合金材料,其产品被广泛运用于测试各种材料,组件和结构在不同环境下的力学性能和特性。
自1946年英斯特朗成立并研制了世界上第一台闭环控制的电子万能材料试验机和第一个应变片式载荷传感器以来,英斯特朗以成为公认的力学性能测试设备世界领导者为使命,通过提供最高品质的产品,专业的技术支持和世界水平的服务,从而使用户获得拥有英斯特朗产品的最佳体验。
英斯特朗新产品系列华北区技术交流会在京召开
英斯特朗:“致承”系列专为中国质控定制
英斯特朗:“致承”系列专为中国质控定制——访英斯特朗中国区业务发展和运营总经理王志勇
喜讯:英斯特朗5960系列获年度最受关注国外仪器荣誉
