方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | HJ 766-2015 固体废物 金属元素的测定 电感耦合等离子体质谱法 |
Fire assay is an established and proven method for testing the purity of gold jewelry and other objects. Nevertheless, it is a destructive and time-consuming process requiring the use of hazardous chemicals. X-ray fluorescence has emerged as a non-destructive alternative to the fire assay method, with comparable accuracy in just minutes. XRF instrumentation is now available in portable units ideally suited for countertop use in retail environments for accurate testing of any precious metal. In a test against two different refineries using fire assay to evaluate two gold ingots from the same melt, an XRF analyzer provided results just as accurate as one refinery, and even more accurate than the second refinery. The test results provided in this article were performed using the Thermo Scientific? Niton? DXL Precious Metal Analyzer.
of gold jewelry and other objects. Nevertheless, it is a destructive and time-consuming process requiring the use of hazardous chemicals. X-ray fluorescence has emerged as a non-destructive alternative to the fire assay method, with comparable accuracy in just minutes. XRF instrumentation is now available in portable units ideally suited for countertop use in retail environments for accurate testing of any precious metal. In a test against two different refineries using fire assay to evaluate two gold ingots from the same melt, an XRF analyzer provided results just as accurate as one refinery, and even more accurate than the second refinery. The test results provided in this article were performed using the Thermo Scientific™ Niton™ DXL Precious Metal Analyzer.
钢构件的碳当量分析测试 使用 Niton Apollo 手持式 LIBS 分析仪
使用Niton Apollo 手持式LIBS 分析仪进行 钢构件的碳当量分析
使用 Niton Apollo 手持式 LIBS 分析仪 不锈钢分析测试
手持式合金分析仪 尼通 Niton XL5 Plus 手持XRF分析仪
Niton 手持激光诱导击穿LIBS光谱分析仪
朗铎科技 FASO 智能在线成分分析仪
朗铎科技FAS 2100手持式X射线荧光光谱仪
手持式矿石分析仪 尼通 Niton XL5
尼通(Niton) 手持式XL2 Plus XRF分析仪
尼通XL2 980便携式光谱仪
Niton尼通 XL3t 980手提合金分析仪
Niton尼通 XL2 手持矿石分析仪
Niton XL3t9500手持式矿石分析仪
Niton XL2 手持式元素分析仪
Niton尼通 XL3t800手持式合金分析仪
手持式光谱仪
合金手持光谱仪
赛默飞世尔尼通手持式光谱仪
