资料下载Quantity size: 0.1ml (200ug/ml, Lyophilized or Liquid. Buffer = 0.01M PBS, pH 7.4 with 10 mg/ml BSA and 0.1% Sodium azide. Reconstitute with 0.2ml sterile distilled water.) Background: Toll-like receptor 4 is a protein that in humans is encoded by the TLR4 gene. TLR 4 is a toll-like receptor. It detects lipopolysaccharide from Gram-negative bacteria and is thus important in the activation of the innate immune system. TLR 4 has also been designated as CD284 (cluster of differentiation 284). The molecular weight of TLR 4 is approximately 95 kDa. Specificity: Rabbit anti- Toll Like Receptor 4 (TLR-4) 9 monoclonal Antibody. Reacts with: Rabbit Application: ELISA=1:500-1000 IHC-P=1:100-500 IHC-F=1:100-500 IF=1:50-200 WB=1:20-200 Not yet tested in other applications. Optimal working dilutions must be determined by the end user. Storage: Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The Lyophilized or Liquid antibody is stable at room temperature for at least one month and for greater than a year when kept at -20 °C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C. Important Note: This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
人基质金属蛋白酶原 1(Pro-MMP-1)酶联免疫吸附测定试剂盒使用说明书
简介:检测原理: 本试剂盒采用双抗体夹心ELISA法。用抗人Pro-MMP-1抗体包被于酶标板上,实验时样品或标准品中的人Pro-MMP-1会与包被抗体结合,游离的成分被洗去。依次加入生物素化的抗人Pro-MMP-1抗体和辣根过氧化物酶标记的亲和素。抗人Pro-MMP-1抗体与结合在包被抗体上的人Pro-MMP-1结合、生物素与亲和素特异性结合而形成免疫复合物,游离的成分被洗去。加入显色底物(TMB),TMB在辣根过氧化物酶的催化下呈现蓝色,加终止液后变成黄色。用酶标仪在450nm波长处测OD值,Pro-MMP-1浓度与OD450值之间呈正比,通过绘制标准曲线计算出样品中Pro-MMP-1的浓度。
兔肌红蛋白(MYO)酶联免疫吸附测定试剂盒使用说明书
简介:试剂盒组成: 中文名称 英文名称 规格 保存条件 ELISA 酶标板(可拆卸) Micro ELISA Plate(Dismountable) 8×12 / 8×6 * 4℃/-20℃ # 冻干标准品 Reference Standard 2/1 支* 4℃/-20℃ # 标准品&样品稀释液 Reference Standard & Sample Diluent 1 瓶 20mL/12mL * 4℃ 浓缩生物素化抗体 Concentrated Biotinylated Detection Ab 1 支 120μL/70μL * 4℃/-20℃ # 生物素化抗体稀释液 Biotinylated Detection Ab Diluent 1 瓶 10mL/6mL * 4℃ 浓缩 HRP 酶结合物 Concentrated HRP Conjugate 1 支 120μL/70μL * 4℃(避光) 酶结合物稀释液 HRP Conjugate Diluent 1 瓶 10mL/6mL * 4℃ 浓缩洗涤液(25×) Concentrated Wash Buffer (25×) 1 瓶 30mL/16mL * 4℃ 底物溶液(TMB) Substrate Reagent 1 瓶 10mL/6mL * 4℃(避光) 反应终止液 Stop Solution 1 瓶 10mL/6mL * 4℃ 封板覆膜 Plate Sealer 5/3 张* 产品说明书 Product Description 1 份 质检报告 Certificate of Analysis 1 份 兔肌红蛋白elisa试剂盒由上海万疆生物专业提供!欢迎咨询!
IL1B Polyclonal Antibody
简介:产品名称: IL1B Polyclonal Antibody 别称: IL1-BETA, IL1F2 货号: EBP20136 来源: Rabbit 亚型: IgG 纯化方法 Affinity purification 组分: PBS with 0.05% sodium azide, 50% glycerol, pH7.3 储存条件: Store at -20℃ . Avoid freeze / thaw cycles. 应用 用途: WB, ELISA 反应性: rat 推荐稀释比: WB 1:100 – 1:400 免疫原信息 名称: Purified recombinant fragment of Rat IL1B expressed in E. Coli 预估 MW: 31kDa 实测 MW: 35kDa 图片 Western blot analysis of human recombinant IL-1β, using IL1B Polyclonal Antibody at dilution of 1:200
万疆生物-elisa试剂盒
简介:BW02111B 大鼠迟现抗原(VLA)ELISA试剂盒 BW02112B 大鼠降钙素(CT)ELISA试剂盒 BW02113B 大鼠骨钙素/骨谷氨酸蛋白(OT/BGP)ELISA试剂盒 BW02114B 大鼠促甲状腺素(TSH)ELISA试剂盒 BW02115B 大鼠皮质醇(Cortisol)ELISA试剂盒 BW02116B 大鼠雌二醇(E2)ELISA试剂盒 BW02117B 大鼠脱氢表雄酮硫酸酯(DHEA-S)ELISA试剂盒 BW02118B 大鼠睾酮(T)ELISA试剂盒 BW02119B 大鼠游离睾酮(F-TESTO)ELISA试剂盒 BW02120B 大鼠雄烯二酮(ASD)ELISA试剂盒 BW02121B 大鼠雌三醇(E3)ELISA试剂盒 BW02122B 大鼠17羟孕酮(17-OHP)ELISA试剂盒 BW02123B 大鼠三碘甲状腺原氨酸(T3)ELISA试剂盒 BW02124B 大鼠甲状腺素(T4)ELISA试剂盒 BW02125B 大鼠游离甲状腺素(FT4)ELISA试剂盒 BW02126B 大鼠游离三碘甲状腺原氨酸(Free-T3)ELISA试剂盒 BW02127B 大鼠新生甲状腺素(NN-T4)ELISA试剂盒 BW02128B 大鼠胰岛素(INS)ELISA试剂盒 BW02129B 大鼠C肽(C-Peptide)ELISA试剂盒 BW02130B 大鼠绒毛膜促性腺激素(CG)ELISA试剂盒 BW02131B 大鼠促黄体激素(LH)ELISA试剂盒 BW02132B 大鼠抗心肌抗体(AMA)ELISA试剂盒 BW02133B 大鼠抗中性粒/中心体抗体(ACA)ELISA试剂盒 BW02134B 大鼠磷脂酰肌醇抗体IgG/IgM(PI Ab-IgG/IgM)ELISA试剂盒 BW02135B 大鼠复合前列腺特异性抗原(CPSA)ELISA试剂盒 BW02136B 大鼠胰蛋白酶(trypsin)ELISA试剂盒 BW02137B 大鼠可溶性瘦素受体(sLR)ELISA试剂盒 BW02138B 大鼠窖蛋白Caveolin1(Cav-1)ELISA试剂盒 BW02139B 大鼠艾杜糖硫酸酯酶(IDS)ELISA试剂盒 BW02140B 大鼠烟酰胺腺嘌呤二核苷酸磷酸(NADPH)ELISA试剂盒
兔白介素(IL-6)elisa试剂盒说明书
小鼠神经肽Y(NP-Y)ELISA试剂盒
小鼠抗凝血酶Ⅲ抗体(AT-Ⅲ)ELISA试剂盒
小鼠上皮中性粒细胞活化肽78(ENA-78/CXCL5)ELISA试剂盒
小鼠主要组织相容性复合体Ⅰ类(MHCⅠ/H-2Ⅰ)ELISA试剂盒
小鼠结蛋白(Des)ELISA试剂盒
小鼠横纹肌辅肌动蛋白α (sm Actinin-α)ELISA试剂盒
小鼠血纤蛋白原(Fbg)ELISA试剂盒
小鼠生长抑素(SS)ELISA试剂盒
小鼠降钙素基因相关肽(CGRP)ELISA试剂盒
小鼠碳酸酐酶(CA)ELISA试剂盒
小鼠内皮脂肪酶(EL)ELISA试剂盒
小鼠妊娠相关血浆蛋白A(PAPP-A)ELISA试剂盒
小鼠高迁移率族蛋白1(HMG-1)ELISA试剂盒
小鼠脱氢表雄酮S7(DHEA-S7)ELISA试剂盒
小鼠水通道蛋白0(AQP-0)ELISA试剂盒
