资料下载产品名称: CTSK Antibody 别称: CTS02; CTSO; CTSO1; CTSO2; MGC23107; PKND; PYCD; 货号: EAP0618 来源: 兔 亚型: IgG 纯化方法: 抗原亲和纯化 性状: 溶液 浓度: 1mg/mL 组分: PBS,0.02% 叠氮钠,50% 甘油, pH7.3 储存条件: 短期使用可保存于-20°C。长期使用可分装后保存于-80°C。避免反复冻融。 应用 用途: WB IHC 反应性: H M R 推荐稀释比: WB(1: 500-1: 2000); IHC(1: 50-1: 200); IF(1: 50-1: 200) 免疫原信息 名称: Recombinant protein of human CTSK 预估 MW: 实测 MW: 39kDa 图片 Western blot analysis of extracts of mouse uterus tissue cell line, using CTSK antibody. www.elabscience.com ELABSCIENCE BIOTECHNOLOGY CO.,LTD FOR RESEARCH USE ONLY Elabscience www.elabscience.cn 背景知识 CTSK(cathepsin K), also named as CTSO, CTSO2, is a recently identified lysosomal cysteine proteinase. CTSK is synthesized as a proenzyme of 38 kDa and subsequently enters acidic lysosomal compartments, in which the propeptide is cleaved and transformed into an active enzyme and it may influence adipocyte differentiation through modifying extracellular matrix components(PMID:16912123). It is revealed both the 46-kDa cathepsin-K precursor and the 30-kDa mature form in mouse bone extracts(PMID:9811821). The high CTSK protein levels are only detected in primary cultured fibroblasts derived from normal and neoplastic breast tissue, where the 37- and 25-kDa bands to be detected correspond to pro- and mature proteins through western blot(PMID:18765527). The full length protein has a signal peptides with 15 amino acids and a propeptide with 99 amino acids. This antibody is specific to CTSK.
人基质金属蛋白酶原 1(Pro-MMP-1)酶联免疫吸附测定试剂盒使用说明书
简介:检测原理: 本试剂盒采用双抗体夹心ELISA法。用抗人Pro-MMP-1抗体包被于酶标板上,实验时样品或标准品中的人Pro-MMP-1会与包被抗体结合,游离的成分被洗去。依次加入生物素化的抗人Pro-MMP-1抗体和辣根过氧化物酶标记的亲和素。抗人Pro-MMP-1抗体与结合在包被抗体上的人Pro-MMP-1结合、生物素与亲和素特异性结合而形成免疫复合物,游离的成分被洗去。加入显色底物(TMB),TMB在辣根过氧化物酶的催化下呈现蓝色,加终止液后变成黄色。用酶标仪在450nm波长处测OD值,Pro-MMP-1浓度与OD450值之间呈正比,通过绘制标准曲线计算出样品中Pro-MMP-1的浓度。
兔肌红蛋白(MYO)酶联免疫吸附测定试剂盒使用说明书
简介:试剂盒组成: 中文名称 英文名称 规格 保存条件 ELISA 酶标板(可拆卸) Micro ELISA Plate(Dismountable) 8×12 / 8×6 * 4℃/-20℃ # 冻干标准品 Reference Standard 2/1 支* 4℃/-20℃ # 标准品&样品稀释液 Reference Standard & Sample Diluent 1 瓶 20mL/12mL * 4℃ 浓缩生物素化抗体 Concentrated Biotinylated Detection Ab 1 支 120μL/70μL * 4℃/-20℃ # 生物素化抗体稀释液 Biotinylated Detection Ab Diluent 1 瓶 10mL/6mL * 4℃ 浓缩 HRP 酶结合物 Concentrated HRP Conjugate 1 支 120μL/70μL * 4℃(避光) 酶结合物稀释液 HRP Conjugate Diluent 1 瓶 10mL/6mL * 4℃ 浓缩洗涤液(25×) Concentrated Wash Buffer (25×) 1 瓶 30mL/16mL * 4℃ 底物溶液(TMB) Substrate Reagent 1 瓶 10mL/6mL * 4℃(避光) 反应终止液 Stop Solution 1 瓶 10mL/6mL * 4℃ 封板覆膜 Plate Sealer 5/3 张* 产品说明书 Product Description 1 份 质检报告 Certificate of Analysis 1 份 兔肌红蛋白elisa试剂盒由上海万疆生物专业提供!欢迎咨询!
IL1B Polyclonal Antibody
简介:产品名称: IL1B Polyclonal Antibody 别称: IL1-BETA, IL1F2 货号: EBP20136 来源: Rabbit 亚型: IgG 纯化方法 Affinity purification 组分: PBS with 0.05% sodium azide, 50% glycerol, pH7.3 储存条件: Store at -20℃ . Avoid freeze / thaw cycles. 应用 用途: WB, ELISA 反应性: rat 推荐稀释比: WB 1:100 – 1:400 免疫原信息 名称: Purified recombinant fragment of Rat IL1B expressed in E. Coli 预估 MW: 31kDa 实测 MW: 35kDa 图片 Western blot analysis of human recombinant IL-1β, using IL1B Polyclonal Antibody at dilution of 1:200
万疆生物-elisa试剂盒
简介:BW02111B 大鼠迟现抗原(VLA)ELISA试剂盒 BW02112B 大鼠降钙素(CT)ELISA试剂盒 BW02113B 大鼠骨钙素/骨谷氨酸蛋白(OT/BGP)ELISA试剂盒 BW02114B 大鼠促甲状腺素(TSH)ELISA试剂盒 BW02115B 大鼠皮质醇(Cortisol)ELISA试剂盒 BW02116B 大鼠雌二醇(E2)ELISA试剂盒 BW02117B 大鼠脱氢表雄酮硫酸酯(DHEA-S)ELISA试剂盒 BW02118B 大鼠睾酮(T)ELISA试剂盒 BW02119B 大鼠游离睾酮(F-TESTO)ELISA试剂盒 BW02120B 大鼠雄烯二酮(ASD)ELISA试剂盒 BW02121B 大鼠雌三醇(E3)ELISA试剂盒 BW02122B 大鼠17羟孕酮(17-OHP)ELISA试剂盒 BW02123B 大鼠三碘甲状腺原氨酸(T3)ELISA试剂盒 BW02124B 大鼠甲状腺素(T4)ELISA试剂盒 BW02125B 大鼠游离甲状腺素(FT4)ELISA试剂盒 BW02126B 大鼠游离三碘甲状腺原氨酸(Free-T3)ELISA试剂盒 BW02127B 大鼠新生甲状腺素(NN-T4)ELISA试剂盒 BW02128B 大鼠胰岛素(INS)ELISA试剂盒 BW02129B 大鼠C肽(C-Peptide)ELISA试剂盒 BW02130B 大鼠绒毛膜促性腺激素(CG)ELISA试剂盒 BW02131B 大鼠促黄体激素(LH)ELISA试剂盒 BW02132B 大鼠抗心肌抗体(AMA)ELISA试剂盒 BW02133B 大鼠抗中性粒/中心体抗体(ACA)ELISA试剂盒 BW02134B 大鼠磷脂酰肌醇抗体IgG/IgM(PI Ab-IgG/IgM)ELISA试剂盒 BW02135B 大鼠复合前列腺特异性抗原(CPSA)ELISA试剂盒 BW02136B 大鼠胰蛋白酶(trypsin)ELISA试剂盒 BW02137B 大鼠可溶性瘦素受体(sLR)ELISA试剂盒 BW02138B 大鼠窖蛋白Caveolin1(Cav-1)ELISA试剂盒 BW02139B 大鼠艾杜糖硫酸酯酶(IDS)ELISA试剂盒 BW02140B 大鼠烟酰胺腺嘌呤二核苷酸磷酸(NADPH)ELISA试剂盒
兔白介素(IL-6)elisa试剂盒说明书
小鼠神经肽Y(NP-Y)ELISA试剂盒
小鼠抗凝血酶Ⅲ抗体(AT-Ⅲ)ELISA试剂盒
小鼠上皮中性粒细胞活化肽78(ENA-78/CXCL5)ELISA试剂盒
小鼠主要组织相容性复合体Ⅰ类(MHCⅠ/H-2Ⅰ)ELISA试剂盒
小鼠结蛋白(Des)ELISA试剂盒
小鼠横纹肌辅肌动蛋白α (sm Actinin-α)ELISA试剂盒
小鼠血纤蛋白原(Fbg)ELISA试剂盒
小鼠生长抑素(SS)ELISA试剂盒
小鼠降钙素基因相关肽(CGRP)ELISA试剂盒
小鼠碳酸酐酶(CA)ELISA试剂盒
小鼠内皮脂肪酶(EL)ELISA试剂盒
小鼠妊娠相关血浆蛋白A(PAPP-A)ELISA试剂盒
小鼠高迁移率族蛋白1(HMG-1)ELISA试剂盒
小鼠脱氢表雄酮S7(DHEA-S7)ELISA试剂盒
小鼠水通道蛋白0(AQP-0)ELISA试剂盒
