ATPIF1蛋白抗体特价
『别名』ATIF1_HUMAN; ATP synthase inhibitor protein; ATPase inhibitor; ATPase inhibitor mitochondrial; ATPase inhibitor protein; ATPase inhibitory factor 1; ATPI; ATPIF 1; ATPIF1; ATPIP; IF(1); IF1; Inhibitor of F(1)F(o)-ATPase; IP; MGC1167; MGC8898; mitochondrial.
『浓度』1mg/1ml
『规格』0.2ml/200μg
『抗体来源』Rabbit
『克隆类型』polyclonal
『交叉反应』Human, Mouse, Rat, Dog, Horse, Rabbit
『产品类型』一抗
『研究领域』肿瘤 细胞生物 信号转导 新陈代谢 线粒体
『蛋白分子量』predicted molecular weight: 10kDa
『性状』Lyophilized or Liquid
『免疫原』KLH conjugated synthetic peptide derived from human ATPIF1/ATPase Inhibitory Factor 1
『亚型』IgG
『纯化方法』affinity purified by Protein A
『储存液』ATPIF1蛋白抗体特价Preservative: 15mM Sodium Azide, Constituents: 1% BSA, 0.01M PBS, pH 7.4
『产品应用』WB=1:100-500 ELISA=1:500-1000 IHC-P=1:100-500 IHC-F=1:100-500 ICC=1:100-500 IF=1:100-500
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
『保存条件』Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
『产品介绍』Mitochondrial ATP synthases (ATPases) transduce the energy contained in membrane electrochemical proton gradients into the energy required for synthesis of high-energy phosphate bonds. ATPases contain two linked complexes: F1, the hydrophilic catalytic core; and F0, the membrane-embedded protein channel. F1 consists of three Alpha chains and three Beta chains, which are weakly homologous, as well as one Gamma chain, one Delta chain and one Gamma chain. F0 consists of three subunits: a, b and c. A mitochondrial F1-ATPase inhibitor protein, ATPIF1 (ATPase inhibitory factor 1), also known as IP, IF1, ATPI or ATPIP (ATPase inhibitor protein), binds to the C-terminal region of a Beta subunit of the F1-ATPase at low pH values and, via interference of the Beta and Gamma subunit interaction, ATPIF1 regulates the activity of the F1F0-ATPase. This reversible ATPIF1 binding to F1F0-ATPase also occurs on the surface of endothelial cells.
Function : Endogenous F(1)F(o)-ATPase inhibitor limiting ATP depletion when the mitochondrial membrane potential falls below a threshold and the F(1)F(o)-ATP synthase starts hydrolyzing ATP to pump protons out of the mitochondrial matrix.
Subunit : Homodimer; represents the active form and is present at a pH value below 6.5. Homotetramer;ATPIF1蛋白抗体特价 represents the inactive form and is present at a pH value above 7.0 (By similarity).
Subcellular Location : Mitochondrion.
Post-translational modifications : Exhibits variability in chain length, mitochondria have distinct pools of protein cleaved after the 24th, 25th, and 26th amino acid.
Similarity : Belongs to the ATPase inhibitor family.
Database links : UniProtKB/Swiss-Prot: Q9UII2.1
植物elisa试剂盒及其耐盐胁迫机制研究新发现
ELISA试剂盒处理和保存方面考虑以下几个方面
霉菌毒素ELISA试剂盒新技术研发
小鼠的尾静脉注射具体操作步骤:
新蝶呤(Neopterin)ELISA检测试剂盒
原卟啉(EP)ELISA检测试剂盒
重酒石酸去甲肾上腺素(NEB)ELISA检测试剂盒
孕激素/孕酮(Pg)ELISA检测试剂盒
游离三碘甲状腺原氨酸(fT3)ELISA检测试剂盒
胰高血糖素样肽2(GLP-2)ELISA检测试剂盒
胸腺五肽(TP5)ELISA检测试剂盒
胸腺肽β4(TMSβ4)ELISA检测试剂盒
胸腺肽β10(TMSβ10)ELISA检测试剂盒
食欲素B/阿立新B(OXB)ELISA检测试剂盒
甲状腺原氨酸(Thyronine)ELISA检测试剂盒
促睡眠肽α(δSIP-α)ELISA检测试剂盒
成骨生长肽/成骨多肽(OGP)ELISA检测试剂盒
间羟肾上腺素(MN)ELISA检测试剂盒
食欲素A/阿立新A(OXA)ELISA检测试剂盒
