磷酸化B-Raf抗体批发
『别名』B Raf (phospho S729); p-B Raf (phospho S729); 94 kDa B raf protein; B raf 1; B Raf proto oncogene serine threonine protein kinase; BRAF 1; Braf; BRAF1; cRmil; MGC126806; MGC138284; Murine sarcoma viral (v-raf) oncogene homolog B1; Murine sarcoma viral v raf oncogene homolog B1; p94; RAFB 1; RAFB1; v raf murine sarcoma viral oncogene homolog B1; FLJ95109.
『浓度』1mg/1ml
『规格』0.1ml/100μg
『抗体来源』Rabbit
『克隆类型』polyclonal
『交叉反应』Human, Mouse, Rat
『产品类型』磷酸化B-Raf抗体批发 一抗 磷酸化抗体
『研究领域』肿瘤 细胞生物 神经生物学 信号转导 细胞凋亡 转录调节因子 激酶和磷酸酶
『蛋白分子量』predicted molecular weight: 94kDa
『性状』Lyophilized or Liquid
『免疫原』KLH conjugated synthesised phosphopeptide derived from human B-Raf around the phosphorylation site of Ser729
『亚型』IgG
『纯化方法』affinity purified by Protein A
『储存液』Preservative: 15mM Sodium Azide, Constituents: 1% BSA, 0.01M PBS, pH 7.4
『产品应用』WB=1:100-500 ELISA=1:500-1000 IHC-P=1:100-500 IHC-F=1:100-500 ICC=1:100-500 IF=1:100-500
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
『保存条件』Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
『产品介绍』The Raf kinases are important intermediates in signal transduction. Raf protein family members, including A Raf and B Raf, have intrinsic serine/threonine kinase activity. Interaction between Ras proteins and Raf proteins results in Raf-mediated phosphorylation and activation of MEK (also known as MAP kinase kinase). Defects in BRAF are involved in a wide range of cancers. B-Raf is a serine/threonine protein kinase that acts as a signal transducer from membrane-associated receptors to nuclear transcription factors. 1 BRAF is important for the regulation of cell proliferation and determination of cell fate during embryogenesis. BRAF acts downstream of Ras and upstream of MEK in the Ras-Raf-MEK-ERK signal transduction pathway, which is a conserved RAS-activated protein kinase cascade that regulates cell growth, proliferation, and differentiation in response to growth factors, cytokines, and hormones.
Function : Involved in the transduction of mitogenic signals from the cell membrane to the nucleus. May play a role in the postsynaptic responses of hippocampal neuron.
Subunit : Monomer. Homodimer. Heterodimerizes with RAF1, and the heterodimer possesses a highly increased kinase activity compared to the respective homodimers or monomers. Heterodimerization is mitogen-regulated and enhanced by 14-3-3 proteins. MAPK1/ERK2 activation can induce a negative feedback that promotes the dissociation of the heterodimer by phosphorylating BRAF at Thr-753. Found in a complex with at least BRAF, HRAS1, MAP2K1, MAPK3 and RGS14. Interacts with RIT1. Interacts (via N-terminus) with RGS14 (via RBD domains); the interaction mediates the formation of a ternary complex with RAF1, a ternary complex inhibited by GNAI1 (By similarity). Interacts with DGKH.
Subcellular Location : Nucleus. Cytoplasm. Cell membrane.
Tissue Specificity : Brain and testis.
Post-translational modifications : Phosphorylation at Ser-365 by SGK1 inhibits its activity.
Methylation at Arg-671 decreases stability and kinase activity.
Ubiquitinated by RNF149; which leads to proteasomal degradation.
DISEASE : Note=Defects in BRAF are found in a wide range of cancers. Defects in BRAF may be a cause of colorectal cancer (CRC) [MIM:114500]. Defects in BRAF are involved in lung cancer (LNCR) [MIM:211980]. LNCR is a common malignancy affecting tissues of the lung. The most common form of lung cancer is non-small cell lung cancer (NSCLC) that can be divided into 3 major histologic subtypes: squamous cell carcinoma, adenocarcinoma, and large cell lung cancer. NSCLC is often diagnosed at an advanced stage and has a poor prognosis.
Defects in BRAF are involved in non-Hodgkin lymphoma (NHL) [MIM:605027]. NHL is a cancer that starts in cells of the lymph system, which is part of the body's immune system. NHLs can occur at any age and are often marked by enlarged lymph nodes, fever and weight loss. Defects in BRAF are a cause of cardiofaciocutaneous syndrome (CFC syndrome) [MIM:115150]; also known as cardio-facio-cutaneous syndrome. CFC syndrome is characterized by a distinctive facial appearance, heart defects and mental retardation. Heart defects include pulmonic stenosis, atrial septal defects and hypertrophic cardiomyopathy. Some affected individuals present with ectodermal abnormalities such as sparse, friable hair, hyperkeratotic skin lesions and a generalized ichthyosis-like condition. Typical facial features are similar to Noonan syndrome. They include high forehead with bitemporal constriction, hypoplastic supraorbital ridges, downslanting palpebral fissures, a depressed nasal bridge, and posteriorly angulated ears with prominent helices. The inheritance of CFC syndrome is autosomal dominant.
Defects in BRAF are the cause of Noonan syndrome type 7 (NS7) [MIM:613706]. Noonan syndrome is a disorder characterized by facial dysmorphic features such as hypertelorism, a downward eyeslant and low-set posteriorly rotated ears. Other features can include short stature, a short neck with webbing or redundancy of skin, cardiac anomalies, deafness, motor delay and variable intellectual deficits.
Defects in BRAF are the cause of LEOPARD syndrome type 3 (LEOPARD3) [MIM:613707]. LEOPARD3 is a disorder characterized by lentigines, electrocardiographic conduction abnormalities, ocular hypertelorism, pulmonic stenosis, abnormalities of genitalia, retardation of growth, and sensorineural deafness.
Similarity : Belongs to the protein kinase superfamily. TKL Ser/Thr protein kinase family. RAF subfamily.磷酸化B-Raf抗体批发 Contains 1 phorbol-ester/DAG-type zinc finger.
Contains 1 protein kinase domain.
Contains 1 RBD (Ras-binding) domain.
Database links : UniProtKB/Swiss-Prot: P15056.4
植物elisa试剂盒及其耐盐胁迫机制研究新发现
ELISA试剂盒处理和保存方面考虑以下几个方面
霉菌毒素ELISA试剂盒新技术研发
小鼠的尾静脉注射具体操作步骤:
新蝶呤(Neopterin)ELISA检测试剂盒
原卟啉(EP)ELISA检测试剂盒
重酒石酸去甲肾上腺素(NEB)ELISA检测试剂盒
孕激素/孕酮(Pg)ELISA检测试剂盒
游离三碘甲状腺原氨酸(fT3)ELISA检测试剂盒
胰高血糖素样肽2(GLP-2)ELISA检测试剂盒
胸腺五肽(TP5)ELISA检测试剂盒
胸腺肽β4(TMSβ4)ELISA检测试剂盒
胸腺肽β10(TMSβ10)ELISA检测试剂盒
食欲素B/阿立新B(OXB)ELISA检测试剂盒
甲状腺原氨酸(Thyronine)ELISA检测试剂盒
促睡眠肽α(δSIP-α)ELISA检测试剂盒
成骨生长肽/成骨多肽(OGP)ELISA检测试剂盒
间羟肾上腺素(MN)ELISA检测试剂盒
食欲素A/阿立新A(OXA)ELISA检测试剂盒
