别名:26RFa; Neuropeptide RF-amide; OX26_HUMAN; pyroglutamylated RFamide peptide; P518; Pyroglutamylated arginine-phenylalanine-amide peptide; QRF-amide; Qrfp.
浓度:1mg/1ml
规格:0.2ml/200μg
抗体来源:Rabbit
克隆类型:polyclonal
交叉反应:Human, Mouse, Rat, Pig, Cow, Horse, Sheep
产品类型:一抗
研究领域:心血管 细胞生物 神经生物学
蛋白分子量:predicted molecular weight: 5kDa
性状:神经内分泌肽QRFP抗体Lyophilized or Liquid
免疫原:KLH conjugated synthetic peptide derived from human QRFP (91-133aa)
亚型:IgG
纯化方法:affinity purified by Protein A
储存液:Preservative: 15mM Sodium Azide, Constituents: 1% BSA, 0.01M PBS, pH 7.4
产品应用:ELISA=1:500-1000 IHC-P=1:100-500 IHC-F=1:100-500 ICC=1:100-500 IF=1:100-500
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
保存条件:Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
产品介绍:QRFP is a 136 amino acid secreted protein that is widely expressed in the brain with highest expression levels in the cerebellum, medulla, pituitary, retina, vestibular nucleus and white matter. Also expressed in the bladder, colon, coronary artery, parathyroid gland, prostate, testis and thyroid, QRFP is a member of the RFamide neuropeptide family. QRFP may be involved in aldosterone secretion by the adrenal gland and is also implicated in stimulating metabolic rate, locomotor activity and increasing blood pressure. Considered a ligand for the G-protein coupled receptor GPR103, QRFP may have orexigenic activity, thereby acting as an appetite stimulant. The gene encoding QFRP is located on human chromosome 9, which consists of about 145 million bases, comprises roughly 4% of the human genome and encodes nearly 900 genes.
Function : Stimulates feeding behavior, metabolic rate and locomotor activity and increases blood pressure. May have orexigenic activity. May promote aldosterone secretion by the adrenal gland.
Subunit : Ligand for the G-protein coupled receptor QRFPR/GPR103
Subcellular Location : Secreted.
Tissue Specificity : Expressed widely in the brain with highest expression levels in the cerebellum, medulla, pituitary, retina, vestibular nucleus, and white matter. Also expressed in the bladder, colon, coronary artery, parathyroid gland, prostate, testis, and thyroid.
Similarity : Belongs to the RFamide neuropeptide family.
Database links : UniProtKB/Swiss-Prot: P83859.1
Cs-(001)-005482 人卵巢透明细胞癌细胞ES-2细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005483 人乳腺癌细胞MDA-MB-436细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005484 人肺鳞癌细胞NCI-H1703细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005485 人肺鳞癌细胞NCI-H2170细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005486 人大细胞肺癌细胞NCI-H460细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005487 人非小细胞肺癌细胞NCI-H524细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005488 人大细胞肺癌细胞NCI-H661细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005489 人小细胞肺癌细胞NCI-H69细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005490 人结直肠腺癌细胞NCI-H716细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005491 人浆细胞白血病细胞NCI-H929细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005492 人卵巢上皮细胞癌细胞OV-1063细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005493 人乳腺上皮细胞DU4475细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005494 人伯基特淋巴瘤细胞EB-3细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005495 人宫颈癌细胞H1HeLa细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005496 人脑胶质瘤细胞HS683细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005497 人膀胱癌细胞J82细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005498 人急性T淋巴细胞白血病细胞Jurkat细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005499 人急性T淋巴细胞白血病细胞JurkatE6-1细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005500 人乳腺导管癌细胞MDA-MB-175Ⅶ细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005501 人乳腺癌细胞MDA-MB-415细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005502 人乳腺导管癌细胞MDA-MB-435细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005503 人宫颈癌瘤株HeLa细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005504 人肾癌细胞769-P细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005505 人肾上腺癌细胞ACHN细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005506 人乳腺癌细胞BT-20细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005507 人乳腺导管癌细胞BT-549[BT549]细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005508 人肾透明细胞癌细胞Caki-2细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005509 人舌鳞癌细胞CAL-27细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005510 人卵巢癌细胞Caov-3细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005511 人结直肠腺癌细胞COLO201细胞 ,规格: >5×100000cells/瓶
Cs-(001)-005512 人脑髓母细胞瘤细胞D283细胞 ,规格: >5×100000cells/瓶
运动为什么可以增强骨强度ELISA试剂盒
ELISA试剂盒组成
国际科研团队ELISA试剂盒称未来转基因婴儿或可接受
积极性记忆有助于情绪紊乱ELISA试剂盒的干预治疗
人免疫球蛋白EFc段受体Ⅱ(CD23)ELISA试剂盒
人免疫球蛋白EFc段受体Ⅱ(FcεRⅡ)ELISA试剂盒
人生存蛋白(Surv)ELISA试剂盒
人抗存活素抗体(Surv)ELISA试剂盒
人吡哆醛/吡哆醇维生素B6激酶(PDXK)ELISA试剂盒
人色氨酰tRNA合成酶(WARS)ELISA试剂盒
人磷脂爬行酶1(PLSCR1)ELISA试剂盒
人C4结合蛋白(C4BP)ELISA试剂盒
人多效生长因子(PTN)ELISA试剂盒
人白三烯D4(LTD4)ELISA试剂盒
人转化生长因子β2(TGFβ2)ELISA试剂盒
白三烯E4(LTE4)elisa检测试剂盒
D二聚体(D2D)elisa检测试剂盒
组织型纤溶酶原激活剂(t-PA)elisa检测试剂盒
组织因子(TF)elisa检测试剂盒
