名称:信号转导和转录激活因子5抗体
别名:signal transducers and activators of transduction 5; MGF; Signal Transducer and Activator of Transcription 5A; STAT 5; STAT 5A; STAT 5B; STAT5; STAT5A; STAT5B; Transcription factor STAT5A; STA5A_HUMAN.
浓度:1mg/1ml
规格:0.1ml/100μg 0.2ml/200μg
抗体来源:Rabbit
克隆类型:polyclonal
交叉反应:Human, Mouse, Rat, Dog, Pig, Cow, Horse, Rabbit
产品类型:一抗
研究领域:免疫学 信号转导 转录调节因子
蛋白分子量:predicted molecular weight: 90kDa
性状:Lyophilized or Liquid
免疫原:KLH conjugated synthetic peptide derived from human STAT 575-125aa
亚型:IgG
纯化方法:affinity purified by Protein A
储存液:0.01M PBS, pH 7.4 with 10 mg/ml BSA and 0.1% Sodium azide
产品应用:WB=1:100-500 ELISA=1:500-1000 IP=1:20-100 IHC-P=1:100-500 IHC-F=1:100-500 IF=1:100-500
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
保存条件:Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
产品介绍:The protein encoded by this gene is a member of the STAT family of transcription factors. In response to cytokines and growth factors, STAT family members are phosphorylated by the receptor associated kinases, and then form homo- or heterodimers that translocate to the cell nucleus where they act as transcription activators. This protein mediates the signal transduction triggered by various cell ligands, such as IL2, IL4, CSF1, and different growth hormones. It has been shown to be involved in diverse biological processes, such as TCR signaling, apoptosis, adult mammary gland development, and sexual dimorphism of liver gene expression. This gene was found to fuse to retinoic acid receptor-alpha (RARA) gene in a small subset of acute promyelocytic leukemias (APLL). The dysregulation of the signaling pathways mediated by this protein may be the cause of the APLL.
Subunit : Forms a homodimer or a heterodimer with a related family member. Binds NR3C1 (By similarity). Interacts with NCOA1 and SOCS7. Interacts with ERBB4.
Subcellular Location : Cytoplasm. Nucleus. Note=Translocated into the nucleus in response to phosphorylation.
Similarity : Belongs to the transcription factor STAT family.
Contains 1 SH2 domain.
Database links :
UniProtKB/Swiss-Prot: P42229.1
Entrez Gene: 6776 Human
Entrez Gene: 6777 Human
Entrez Gene: 20850 Mouse
Entrez Gene: 20851 Mouse
Entrez Gene: 24918 Rat
Entrez Gene: 25126 Rat
Omim: 601511 Human
Omim: 604260 Human
转录调节因子(Transcriptin Regulators)
STAT-信号转导和转录激活因子蛋白家族是近年来发现的一类转录因子.通过JAK-STAT途径介导许多由细胞因子诱导的反应,参与细胞的信号转导和转录。
运动为什么可以增强骨强度ELISA试剂盒
ELISA试剂盒组成
国际科研团队ELISA试剂盒称未来转基因婴儿或可接受
积极性记忆有助于情绪紊乱ELISA试剂盒的干预治疗
人免疫球蛋白EFc段受体Ⅱ(CD23)ELISA试剂盒
人免疫球蛋白EFc段受体Ⅱ(FcεRⅡ)ELISA试剂盒
人生存蛋白(Surv)ELISA试剂盒
人抗存活素抗体(Surv)ELISA试剂盒
人吡哆醛/吡哆醇维生素B6激酶(PDXK)ELISA试剂盒
人色氨酰tRNA合成酶(WARS)ELISA试剂盒
人磷脂爬行酶1(PLSCR1)ELISA试剂盒
人C4结合蛋白(C4BP)ELISA试剂盒
人多效生长因子(PTN)ELISA试剂盒
人白三烯D4(LTD4)ELISA试剂盒
人转化生长因子β2(TGFβ2)ELISA试剂盒
白三烯E4(LTE4)elisa检测试剂盒
D二聚体(D2D)elisa检测试剂盒
组织型纤溶酶原激活剂(t-PA)elisa检测试剂盒
组织因子(TF)elisa检测试剂盒
