中文名称:增食欲素A/欲激素A抗体
别名:HCRT 1; HCRT; HCRT1; HCRT2; Hypocretin (orexin) neuropeptide precursor; Hypocretin 1; Hypocretin 2; Hypocretin A; Hypocretin; Hypocretin neuropeptide precursor; Hypocretin1; NRCLP1; Orexin A; Orexin; Orexin B; Orexin precursor; OrexinA; OX; PPORX; PPOX; PREPROOREXIN; OREX_HUMAN.
浓度:1mg/1ml
规格:0.2ml/200μg
抗体来源:Rabbit
克隆类型:polyclonal
交叉反应:Human
产品类型:一抗
研究领域:
性状:Lyophilized or Liquid
免疫原:KLH conjugated synthetic peptide derived from human Orexin A
亚型:IgG
纯化方法:affinity purified by Protein A
储存液:Preservative: 15mM Sodium Azide, Constituents: 1% BSA, 0.01M PBS, pH 7.4
产品应用:WB=1:100-500 ELISA=1:500-1000 IP=1:20-100 IHC-P=1:100-500 IHC-F=1:100-500 ICC=1:100-500 IF=1:100-500
(石蜡切片需做抗原修复)
not yet tested in other applications.
optimal dilutions/concentrations should be determined by the end user.
保存条件:Store at -20 °C for one year. Avoid repeated freeze/thaw cycles. The lyophilized antibody is stable at room temperature for at least one month and for greater than a year when kept at -20°C. When reconstituted in sterile pH 7.4 0.01M PBS or diluent of antibody the antibody is stable for at least two weeks at 2-4 °C.
Important Note This product as supplied is intended for research use only, not for use in human, therapeutic or diagnostic applications.
产品介绍:Orexin A (hypocretin 1) a 33 amino acid peptide and orexin B (hypocretin 2), a 28 amino acid peptide, are both derived from a common 130 amino acid precursor, prepro orexin. Orexin A and Orexin B stimulate food consumption when administered intracerebroventricularly to rats. Orexin gene expression in the brain is highly restricted to distinct populations of neurons located in specific hypothalamic regions, including the lateral hypothalamic area (LHA), a region implicated in feeding behaviour. Orexin A and orexin B bind to and activate two closely related G protein coupled receptors (GPCRs), termed Orexin 1 (OX1) and Orexin 2 (OX2) receptors. Dysfunction of the orexin peptide system has been linked to narcolepsy.
Function : Neuropeptides that play a significant role in the regulation of food intake and sleep-wakefulness, possibly by coordinating the complex behavioral and physiologic responses of these complementary homeostatic functions. A broader role in the homeostatic regulation of energy metabolism, autonomic function, hormonal balance and the regulation of body fluids, is also suggested. Orexin-A binds to both OX1R and OX2R with a high affinity, whereas orexin-B binds only to OX2R with a similar high affinity.
Subcellular Location : Rough endoplasmic reticulum. Cytoplasmic vesicle. Cell junction, synapse. Note=Associated with perikaryal rough endoplasmic reticulum as well as cytoplasmic large granular vesicles at synapses.
Tissue Specificity : Abundantly expressed in subthalamic nucleus but undetectable in other brain regions tested (hypothalamus was not tested) and in heart, placenta, lung, liver, skeletal muscle, kidney and pancreas.
Post-translational modifications : Specific enzymatic cleavages at paired basic residues yield the different active peptides.
DISEASE : Defects in HCRT are the cause of narcolepsy type 1 (NRCLP1) MIM:161400:. Narcolepsy is a neurological disabling sleep disorder, characterized by excessive daytime sleepiness, sleep fragmentation, symptoms of abnormal rapid-eye-movement (REM) sleep, such as cataplexy, hypnagogic hallucinations, and sleep paralysis. Cataplexy is a sudden loss of muscle tone triggered by emotions, which is the most valuable clinical feature used to diagnose narcolepsy. Human narcolepsy is primarily a sporadically occurring disorder but familial clustering has been observed. Note=Human narcolepsy is associated with a deficient orexin system. Orexins are absent and/or greatly diminished in the brain and cerebrospinal fluid (CSF) of most narcoleptic patients.
Similarity : Belongs to the orexin family.
Database links : UniProtKB/Swiss-Prot: O43612.1
运动为什么可以增强骨强度ELISA试剂盒
ELISA试剂盒组成
国际科研团队ELISA试剂盒称未来转基因婴儿或可接受
积极性记忆有助于情绪紊乱ELISA试剂盒的干预治疗
人免疫球蛋白EFc段受体Ⅱ(CD23)ELISA试剂盒
人免疫球蛋白EFc段受体Ⅱ(FcεRⅡ)ELISA试剂盒
人生存蛋白(Surv)ELISA试剂盒
人抗存活素抗体(Surv)ELISA试剂盒
人吡哆醛/吡哆醇维生素B6激酶(PDXK)ELISA试剂盒
人色氨酰tRNA合成酶(WARS)ELISA试剂盒
人磷脂爬行酶1(PLSCR1)ELISA试剂盒
人C4结合蛋白(C4BP)ELISA试剂盒
人多效生长因子(PTN)ELISA试剂盒
人白三烯D4(LTD4)ELISA试剂盒
人转化生长因子β2(TGFβ2)ELISA试剂盒
白三烯E4(LTE4)elisa检测试剂盒
D二聚体(D2D)elisa检测试剂盒
组织型纤溶酶原激活剂(t-PA)elisa检测试剂盒
组织因子(TF)elisa检测试剂盒
