Calibration of an Au-coated Quartz Crystal
2015-05-22 14:58  下载量:4
资料下载
This Application Note is the second in a series relating to the eQCM 10M? and assumes that you have read and understand the material covered in the Application Note, Basics of a Quartz Crystal Microbalance. The purpose of this Application Note is to show the reader a simple experiment where we reduce Cu2+ onto an Au electrode and then oxidize Cu back off. We will then use the result to calculate a calibration factor for the crystal. Conversely, we will show you how to calculate the molar mass of the species deposited using a calibration factor. Each crystal has a theoretical calibration factor, however, under typical experimental conditions, these calibration factors will vary slightly. We will use Cu2+ to calculate a calibration factor which could then be used in subsequent experiments on the same crystal.
资料下载
文献贡献者
相关资料 更多
当前位置: Gamry 资料 Calibration of an Au-coated Quartz Crystal
