Changing Potentiostat Speed Settings
2015-05-22 15:02  下载量:3
资料下载
This application note describes the software changes that you can make to slow down a Gamry Instruments’ potentiostat. Slowing down the potentiostat can improve its stability. These changes presume a working knowledge of Gamry Instruments’ Explain? scripting language. The Gamry Framework Tutorial contains an exercise in which you make changes to a script. We highly recommend that you review the Tutorial material prior to making changes. Some predesigned experiments in Gamry Instruments’ Framework software already incorporate the ability to change the speed of the potentiostat, such as within the Physical Electrochemistry group of experiments.
资料下载
文献贡献者
相关资料 更多
当前位置: Gamry 资料 Changing Potentiostat Speed Settings
