资料下载Macro-dispersion of carbon black and silica in rubber compounds may be measured by different methods. Carbon black provides a direct physical reinforcement; silica requires a silane coupling agent in order to initiate reinforcement, and therefore, a different technology of mixing. Silica is also a non-conductor, making electrical methods of dispersion measurement impracticable. This test method is specifically appropriate for the characterization of the microdispersion in silica technology. This test method also can measure the mixing quality of colored rubbers. It uses variable exposure in order to be able to image a wide range of colors. This test method is intended for use in research and development as well as in quality control of filler processability in rubber and may be used for both the evaluation of production processes or referee purposes.
GB/T16589-1996 硫化橡胶分类:橡胶材料
简介:GB/T16589-1996 硫化橡胶分类:橡胶材料,GB/T16589-1996 硫化橡胶分类:橡胶材料
GBT 16585-1996 硫化橡胶人工气候老化(荧光紫外灯)试验方法
简介:GBT 16585-1996 硫化橡胶人工气候老化(荧光紫外灯)试验方法,GBT 16585-1996 硫化橡胶人工气候老化(荧光紫外灯)试验方法
GB/T 11206-2009 橡胶老化试验 表面龟裂法
简介:GB/T 11206-2009 橡胶老化试验 表面龟裂法,GB/T 11206-2009 橡胶老化试验 表面龟裂法
GBT15254-2014 硫化橡胶 与金属粘接 180°剥离试验
简介:GBT15254-2014 硫化橡胶 与金属粘接 180°剥离试验,GBT15254-2014 硫化橡胶 与金属粘接 180°剥离试验
GBT3517-2002 天然生胶塑性保持率的测定
简介:GBT3517-2002 天然生胶塑性保持率的测定,GBT3517-2002 天然生胶塑性保持率的测定,GBT3517-2002 天然生胶塑性保持率的测定
