资料下载Gilson DISPENSMAN™ 瓶口分液器能快速、简单以及精准得分配需要的液体量。可单手设定体积的按钮,操作简单且安全。
TN224-01-Gilson液样平台对样品纯化后分析样品制备的自动化应用(英文)
简介:INTRODUCTION Following successful purification of small molecule drug candidates, it is necessary to pool the fractions, dry down those pooled fractions, and then prepare samples for analysis from this dried solid. Usually, the analysis of choice is a combination of analytical LCMS and NMR. To do this, it is necessary to re-dissolve the dried solid in a known quantity of a suitable solvent and then transfer small aliquots from this sample into the appropriate analysis tubes and vials.
TN223-01-基于Gilson 223自动进样器实现牛奶铜皂法和氨基黑法检测的自动化(英文)
简介:INTRODUCTION In laboratories specializing in milk analysis, there are two methods where Gilson could help with a semi- or full automation of the complete protocols. In comparison to the manual procedure, automation provides more robust and reproducible results and sample traceability. The first method is the Copper Soap method for the calculation of the Lipolysis Index. The second method is the Amido Black method for the calculation of protein content in milk.
TN222-01-基于Gilson GX-271液样处理平台和 UV1800紫外可见分光光度计的自动分光光度法检测的应用(英文)
简介:INTRODUCTION A general liquid handling application is to use a liquid handler as an autosampler for a spectrophotometer. The traditional manual method for filling a flow-through cuvette is to use a peristaltic pump (a sipper) to draw the sample through the cuvette. This can easily be replicated using a Gilson GX liquid handler.
TN221-01-使用Gilson VERITY® 271 LCMS质谱引导制备色谱系统分离多肽混合物(英文)
简介:INTRODUCTION Preparative LC coupled with mass spectrometry (MS) is a well-established method for purifying target compounds. The VERITY® 271 LCMS system (Figure 1) leverages the separating power of HPLC with the detection capabilities of MS to isolate fractions with high purity and achieve excellent recovery for target molecules. The system incorporates signal data from both ultraviolet (UV) and mass-based detectors.
Gilson吉尔森ROTO微型多功能旋转混匀仪数控样品混合
Gilson吉尔森迷你涡旋混匀仪小型混匀器振荡器漩涡混匀
Gilson吉尔森数显微型培养箱手提式便携式培养箱
Gilson吉尔森数显干式金属浴多模块加热器恒温孵育器干浴
Gilson吉尔森CENTRY™103迷你型离心机便携式掌上离心机
Gilson吉尔森CENTRY™101微孔板离心机96孔细胞板用微型离心机
Gilson吉尔森CENTRY™117微量台式离心机便携式数显定时离心机
Gilson吉尔森ASPEC® 正压固相萃取仪
Gilson吉尔森GX-271 ASPEC®全自动固相萃取系统
Gilson GX-241 ASPEC®全自动固相萃取系统
Gilson吉尔森Gilson安全吸液工作站多功能吸液真空吸液器
Gilson吉尔森PIPETMAN® L单道移液器单通道移液枪
Gilson吉尔森PIPETMAN® G移液器移液枪
Gilson吉尔森DISPENSMAN® 瓶口分液器大体积分液
