方案下载应用领域 | 其他 |
检测样本 | 其他 |
检测项目 | |
参考标准 | radleys 反应釜, 2L, |
1.可实现的最低温度为:-50℃。 2.能够通过控制器自带的编程功能进行程序控温。 3.温度精准度可达±0.01
CC®-505
CC®-505 cycling a 2 litre Radleys jacketed
reactor
Requirement
This case study demonstrates the ability of the
CC-505 refrigeration bath circulator to cycle the
process temperature in a range from +20°C
to -50°C, the closeness of the temperature
control and the minimum process temperature
achievable in the process mass.
Method
The 2 litre Radleys reactor was connected to the
CC-505 using two M24x1.5 1-meter flexible
hoses. The thermofluid used in the system was
M40.165.10. “Process” control was carried out
via a Pt100 sensor located in the process mass.
Stirrer speed was set to 200 rpm.
Setup details
Temperature range: -50°C...+200°C
Cooling power: 1.2 kW @ +100°C
1.2 kW @ +20°C
1.0 kW @ 0°C
0.6 kW @ -20°C
0.15 kW @ -40°C
Heating power: 1.5 kW
Hoses: M24x1.5; 2* 1 m
HTF: M40.165.10
Reactor: Radleys 2 litre
jacketed reactor
Reactor content: 1.5 litre M40.165.10
Stirrer speed: 200 rpm
Control: process
results
Performance:
Cooling down and heating up in a range from +20°C to -20°C.
The CC-505 needs approximately 45 minutes to cool down the reactor
from +20°C to -20°C and 35 minutes to heat it up from -20°C to +20°C.
Lowest achievable temperature (Tmin):
Once stable at +20°C under “Process“ control, a set-point of -50°C is
entered. The CC-505 cools the reactor down to the minimum achievable
process temperature of -34°C.
温度控制在发酵工艺的应用
汽车行业专用温控技术
溶解度测定与结晶
完美适配蒸发任务的冷阱——CT50
超小型实验室制冷循环器 Piccolo
Huber Chili“小辣椒”加热循环器
Huber Unistat TR401w HT
Huber Unistat T340w HT
Huber Unistat T330w HT
Huber Unistat T320w HT
Huber Unistat T305w HT
Huber Unistat T305 HT
Huber Unistat 950w
Huber Unistat 920w
Huber Unistat 915w
Huber Unistat 912w
Huber Unistat 905w
Huber Unistat 825w
