Significant increase of Curie temperature in nano-scale BaTiO3
Yueliang Li1, Zhenyu Liao1, Fang Fang1, Xiaohui Wang2, Longtu Li2 and Jing Zhu1,a)
Appl. Phys. Lett. 105, 182901 (2014); http://dx.doi.org/10.1063/1.4901169
Abstract:
The low Curie temperature (Tc ?=?130?°C) of bulk BaTiO3 greatly limits its applications. In this work, the phase structures of BaTiO3 nanoparticles with sizes ranging from 2.5?nm to 10?nm were studied at various temperatures by using aberration-corrected transmission electron microscopy (TEM) equipped with an in-situ heating holder. The results implied that each BaTiO3 nanoparticle was composed of different phases, and the ferroelectric ones were observed in the shells due to the complicated surface structure. The ferroelectric phases in BaTiO3 nanoparticles remained at 600?°C, suggesting a significant increase of Tc . Based on the in-situ TEM results and the data reported by others, temperature-size phase diagrams for BaTiO3 particles and ceramics were proposed, showing that the phase transition became diffused and the Tc obviously increased with decreasing size. The present work sheds light on the design and fabrication of advanced devices for high temperature applications.
DENSsolutions原位新技术亮相2020年电子显微学学术年会
2019下半年,我在这里等你!
原位气体加热系统结合质谱表征纳米颗粒结构组分变化与催化活性关系!
原位加热样品杆为研究原子尺度纳米晶生长模式提供直接证据!
