As one of the hottest new technologies in global IVD market, liquid nitrogen(LN2) bead technology has enjoyed fast development in the past two years. From USA, Germany, United Kingdom, and China, many overseas multinational corporations and domestic biotech companies are preparing for LN2 bead technology research and development, small scale production, and large scale production. Among overseas domestic IVD trade shows, both reagent manufacturers and testing device manufacturers are paying more and more attention to LN2 bead technology. As multinational corporations are accelerating LN2 bead from technology development to large scale production, LN2 bead will become one of the mainstream IVD technologies in the near future.
Liquid reagent requires low temperature transportation and storage at high cost. In addition, liquid reagent has unstable condition and short life cycle.
Compared to liquid reagent, LN2 solid bead made from reagent has many advantages as listed below. As future mass production drives LN2 bead cost, LN2 bead technology will definitely drive IVD instant diagnostics to a new level of explosive growth.
LN2 bead technology advantages
· Precision test accuracy.
· Top choice for instant diagnostics
· LN2 bead room temperature transportation and storage drives down total cost.
· Bead’s loose reticular structure allows fast re-dissolution.
· Maximized enzyme / protein’s activeness and lifetime.
· Wide range of applications, such as nucleic acid / PCR testing, immunoassay, environmental testing.
LN2 production process and key technology challenges.
LN2 bead production equipment evolution:
Guangzhou Ascend Precision Machinery Company (www.ascendgz.com) has officially launched its latest DS528 automatic precision LN2 bead dispensing system. The system has the following unique technology advantages.
1、 Safe and automatic LN2 addition
LN2 has ultra low temperature and continuous evaporation feature. LN2 addition requires production room ventilation and equipment safety measurements to ensure operator safety.
Guangzhou Ascend DS528 includes unique automatic LN2 addition system. During production, high and low LN2 liquid level sensors will check liquid level change and trigger system to add LN2 to LN2 container to ensure sufficient LN2 supply for automatic bead production.
2、Automatic bead harvesting
DS528 has incorporated automatic robot to harvest beads from LN2 container for easy and fast bead transfer.
3、Bead packaging
Guangzhou Ascend can provide bead packaging solutions for packing beads into chain tube, vials, cards, or plates. Custom bead packaging solutions are available for small scale to large scale automatic bead packaging.
4、Micro volume ceramic pump for precision dispensing.
DS528 uses smart ceramic pump for precision bead dispensing. Lowest volume goes down to 0.5ul (bead OD 1mm). Bead size can be digitally adjusted. Bead size accuracy can be as high as 0.5%. Custom made dispensing tip eliminates the issue of fluid residue on tip and bead cracking issue. DS528 can produce beads of fine sphericity as well as uniform size and shape.
5、High throughput for mass production
DS528 system production output can be as high as 20,000 beads per hour. A wide selection of dispensing channels can be selected to cover small scale to large scale bead production.
Guangzhou Ascend also provides options of fluid temperature control device and fluid agitation device to meet individual customer’s application needs. Based on years of experience in LN2 bead technology, Guangzhou Ascend is dedicated to provide one stop & shop for LN2 bead system and solutions to global IVD customers.
Guangzhou Ascend Precision Machinery Company is a high-tech company that specializes in high precision fluid control equipment and system solutions. The company has designed and manufactured a variety of LN2 bead dispensing systems and solutions to top research universities & institutes, public traded companies and industry recognized IVD companies in USA, UK, Russia, China, etc. As the technology and system leader in LN2 bead application, Guangzhou Ascend is dedicated to contribute to LN2 bead’s promising and shining future in IVD industry.
广州飞升 | 第二代FSH-LA线性注液泵,助力圆柱、数码电池注液
发力中段高增量赛道 核心部件“护航”注液高精度
预灌封注射器/预冲式冲管注射器 硅油喷涂核心技术及解决方案
高精密微量喷涂核心技术及解决方案
广州飞升 FSH-MIC-A系列微量点液/清洗泵
广州飞升 FS-V-F(LG) 防滴液阀
广州飞升FS-V-F60 防滴液阀
广州飞升FSH-DS228-F-Pro型液氮冻干微球系统
飞升FSH-DS528全自动液氮冻干珠点小球系统
飞升FSH-DS628冻干珠自动分装设备
美国IVEK-Sonicair声波气动硅油采血管喷涂雾化装置
飞升FSH-VLIV高真空点液阀
飞升FS-VIV-P高真空点液阀
飞升FSH-DS228-F液氮冻干珠点小球系统
飞升FSH-DS228-T试剂冻干珠系统
飞升FSH-CF恒流泵
飞升FSH-SK08分装泵
飞升FSH-SKAP微量点液计量泵
飞升FSH-SK10智能灌装泵
