资料下载The HyperFine series of spectrometers are based on LightMachinery's patented fluid jet polishing technology. Designed for measuring hyperfine spectra and subtle spectral shiVs, the HyperFine spectrometer from LightMachinery is a compact spectrometer capable of 1 picometer resolu.on. It is ideal for measuring fine features in plasmas, pulsed laser characteriza0on and for measuring the small spectral shiVs from Brillouin or Raman scaZering. Simple PC based soVware allows the user to review spectra in real 0me and save or export for more analysis. LabView drivers enable the HyperFine spectrometer to be integrated into automated experimental setups.
WPI液体波导毛细管流通池LWCC
简介: 典型的比色皿和流通池光程位于2毫米和10厘米之间,由于机械约束很难开发更长的光程。WPI公司生产的液体波导毛细管流通池(LWCC)填补了这个空隙。 液体波导毛细管流通池(LWCC)是一种基于光纤技术的流通池,将不同光程(2毫米-500厘米)光学通路结合少量液体样品(2.4微升-3000微升)检测的检测技术。
自由基分析仪
简介:SYS-900A 微压测量系统可用于测量小血管、细胞和其它电解质槽液灌注的微囊静水压,检测范围为-200 毫米汞柱至+400 毫米汞柱,该仪器非常稳定和精确。微压测量系统包括主控制板、电机、独立压力控制器和带有放大器、压电阀和压力传感器的机壳组成。压力控制器很轻巧,它可放在靠近微电极的位置以便减少死腔。
吸光度测量的四个建议
简介:设置合适的积分时间,使原始信号的强度达到光谱仪最大强度的80%左右。在允许的范围内,尽可能大地使用光谱平均;平滑设置的数值要与光谱仪的像元分辨率相近,过大的平滑数,会影响到结果的光谱分辨率。
UltraBright光谱仪
简介:Your spectrometer would work great if you had 100X the light. Problem solved. Introducing the UltraBright Spectrometers from LightMachinery. No slit, just a giant aperture and a huge field of view. Boom.
光谱分析仪
简介:The Optical Spectrum Analyzer has been a work horse for the telecommunicaBons industry for decades. We thought it was Bme to revoluBonize the performance of the OSA and re-think the design of the instrument. The Ultra-OSA solves the biggest drawback of the technology (speed) while retaining the resoluBon and sensiBvity.
