资料下载short-pulse (TEA) CO2 lasers (originally developed by Lumonics Inc. and now offered by LightMachinery Inc.) are primarily designed for fine processing of non-metallic materials. The IMPACT-2000 Series lasers are ideally suited for the selec(ve removal or machining of non-metallic layers deposited on a metallic under-layer. Unlike conven(onal CO2 lasers, the short pulses and high peak powers of TEA CO2 lasers enable the surface layer to be removed (“ablated”) with li:le or no ! www.lightmachinery.com IMPACT-2000 Series effect on the underlying metal substrate, and with minimal thermal damage (“heat-affected zone” or “HAZ”) to the surrounding polymer material.
WPI液体波导毛细管流通池LWCC
简介: 典型的比色皿和流通池光程位于2毫米和10厘米之间,由于机械约束很难开发更长的光程。WPI公司生产的液体波导毛细管流通池(LWCC)填补了这个空隙。 液体波导毛细管流通池(LWCC)是一种基于光纤技术的流通池,将不同光程(2毫米-500厘米)光学通路结合少量液体样品(2.4微升-3000微升)检测的检测技术。
自由基分析仪
简介:SYS-900A 微压测量系统可用于测量小血管、细胞和其它电解质槽液灌注的微囊静水压,检测范围为-200 毫米汞柱至+400 毫米汞柱,该仪器非常稳定和精确。微压测量系统包括主控制板、电机、独立压力控制器和带有放大器、压电阀和压力传感器的机壳组成。压力控制器很轻巧,它可放在靠近微电极的位置以便减少死腔。
吸光度测量的四个建议
简介:设置合适的积分时间,使原始信号的强度达到光谱仪最大强度的80%左右。在允许的范围内,尽可能大地使用光谱平均;平滑设置的数值要与光谱仪的像元分辨率相近,过大的平滑数,会影响到结果的光谱分辨率。
UltraBright光谱仪
简介:Your spectrometer would work great if you had 100X the light. Problem solved. Introducing the UltraBright Spectrometers from LightMachinery. No slit, just a giant aperture and a huge field of view. Boom.
光谱分析仪
简介:The Optical Spectrum Analyzer has been a work horse for the telecommunicaBons industry for decades. We thought it was Bme to revoluBonize the performance of the OSA and re-think the design of the instrument. The Ultra-OSA solves the biggest drawback of the technology (speed) while retaining the resoluBon and sensiBvity.
