利用Dualex植物多酚测量仪估算冬小麦氮素
Dualex便携式氮平衡-叶绿素-花青素-黄酮醇测量仪
摘要
更好地了解小麦氮素状况对于改善精准农业中的氮肥管理非常重要。在这项研究中,评估了四种不同传感器估算冬小麦氮素的能力。采用高斯过程回归(GPR)方法和顺序向后特征去除(SBBR)程序,确定了不同传感器对小麦氮素指标敏感的植被指数(VIs)的最佳组合。通过参数回归(PR)、多变量线性回归(MLR)和高斯过程回归(GPR),利用VIs估计小麦叶片氮浓度(LNC)、植株氮浓度(PNC)和营养指数(NNI)。研究结果表明,在低冠层覆盖条件下,光学荧光传感器可以更准确地估计冬小麦氮素状况。双氮平衡指数(NBI)是小麦生长早期LNC、PNC和NNI的最佳叶片水平指标。在生长早期,复合指数是LNC、PNC和NNI的最佳冠层水平指标。在生长后期,ASD-VIs为小麦氮素指标提供了准确的估计。这项研究还表明,与MLR和PR方法相比,GPR结合SBBR分析方法可以更准确地估计冬小麦LNC、PNC和NNI,并为这些传感器在不同冬小麦生长阶段提供最佳VI组合。
关键词:叶片氮浓度;植物含氮量;氮素营养指数;高斯过程回归
Winter Wheat Nitrogen Estimation Based on Ground-Level and UAV-Mounted Sensors
Abstract
A better understanding of wheat nitrogen status is important for improving N fertilizer management in precision farming. In this study, four different sensors were evaluated for their ability to estimate winter wheat nitrogen. A Gaussian process regression (GPR) method with the sequential backward feature removal (SBBR) routine was used to identify the best combinations of vegetation indices (VIs) sensitive to wheat N indicators for different sensors. Wheat leaf N concentration (LNC), plant N concentration (PNC), and the nutrition index (NNI) were estimated by the VIs through parametric regression (PR), multivariable linear regression (MLR), and Gaussian process regression (GPR). The study results reveal that the optical fluorescence sensor provides more accurate estimates of winter wheat N status at a low-canopy coverage condition. The Dualex Nitrogen Balance Index (NBI) is the best leaf-level indicator for wheat LNC, PNC and NNI at the early wheat growth stage. At the early growth stage, Multiplex indices are the best canopy-level indicators for LNC, PNC, and NNI. At the late growth stage, ASD VIs provide accurate estimates for wheat N indicators. This study also reveals that the GPR with SBBR analysis method provides more accurate estimates of winter wheat LNC, PNC, and NNI, with the best VI combinations for these sensors across the different winter wheat growth stages, compared with the MLR and PR methods.
Keywords: leaf nitrogen concentration; plant nitrogen content; nitrogen nutrition index; Gaussian process regression
相关阅读
PESSL便携式Dualex便携式植物多酚-叶绿素仪原理
Dualex植物多酚-叶绿素仪:腐殖酸通过铁依赖和非铁依赖的协同机制缓解禾本科植物的铁失绿症
Dualex植物多酚-叶绿素仪:硝化抑制剂和/或间作效应下玉米(和小麦灌溉种植系统中的硝酸盐淋失
Dualex植物多酚-叶绿素仪:与保持绿色表达相关的叶片和冠层性状与对水分胁迫具有不同耐性的小麦基因型的产量构成密切相关
阅读14次
最新动态
推荐产品
当前位置: 博普特 动态 利用Dualex植物多酚测量仪估算冬小麦氮素
