摘要
对比环境生长条件(体外组织培养、体外驯化、气候室、温室和室外)对Populus × canescens clone 84 K叶片发育、角质层蜡组成和离体叶片蒸腾的影响 进行了调查。我们的结果表明,在不同的生长条件下培养时,角质层蜡的总量增加了10倍以上,而蜡的质量组成没有改变。除了直接从组织培养中获得的表现出快速脱水的植株外,完整但分离的叶片的失水率(残余叶片蒸腾)是恒定的,与生长条件无关,因此与蜡含量的增加无关。由于用分离的Astomotous P.×canescens角质层测量的角质层蒸腾速率与离体叶片的残余叶蒸腾速率相同,我们的结果证实,通过气孔关闭后离体叶片的残余蒸腾速率,可以高精度地预测P.×canescens叶片的角质层蒸腾速率。我们的结果令人信服地表明,P.×canescens角质层中蜡含量增加10倍以上不会导致残余(角质层)蒸腾速率降低。
Increased cuticular wax deposition does not change residual foliar transpiration
Abstract
The effect of contrasting environmental growth conditions (in vitro tissue culture, ex vitro acclimatisation, climate chamber, greenhouse and outdoor) on leaf development, cuticular wax composition, and foliar transpiration of detached leaves of the Populus × canescens clone 84 K were investigated. Our results show that total amounts of cuticular wax increased more than 10-fold when cultivated in different growth conditions, whereas qualitative wax composition did not change. With exception of plants directly taken from tissue culture showing rapid dehydration, rates of water loss (residual foliar transpiration) of intact but detached leaves were constant and independent from growth conditions and thus independent from increasing wax amounts. Since cuticular transpiration measured with isolated astomatous P. × canescens cuticles was identical to residual foliar transpiration rates of detached leaves, our results confirm that cuticular transpiration of P. × canescens leaves can be predicted with high accuracy from residual transpiration of detached leaves after stomatal closure. Our results convincingly show that more than 10-fold increased wax amounts in P. × canescens cuticles do not lead to decreased rates of residual (cuticular) transpiration.
相关阅读
PESSL便携式Dualex便携式植物多酚-叶绿素仪原理
Dualex植物多酚-叶绿素仪:腐殖酸通过铁依赖和非铁依赖的协同机制缓解禾本科植物的铁失绿症
Dualex植物多酚-叶绿素仪:硝化抑制剂和/或间作效应下玉米(和小麦灌溉种植系统中的硝酸盐淋失
Dualex植物多酚-叶绿素仪:与保持绿色表达相关的叶片和冠层性状与对水分胁迫具有不同耐性的小麦基因型的产量构成密切相关
利用Pessl叶绿素仪植物多酚Dualex发表过的文章
博普特圆满参展2024中国园艺学会
博普特合作伙伴Videometer参加ISTA成立100周年种子会议
科学家利用博普特合作伙伴Videometer的多光谱成像系统发表糖衣替代物研究文章
