旱是影响植物生长和生产力的主要限制因素之一。干旱胁迫通过一系列解剖、形态、生理和生化变化以不同方式影响植物生长。因此,开发替代方法来保护植物免受干旱胁迫非常重要。土耳其拥有包括金盏花在内的各种药用和芳香植物最独特的种植区之一。尽管其作为药用植物具有相当的重要性和用途,但其商业生产非常有限。本研究在正常灌溉(K1)、50%灌溉(K2)和25%灌溉(K3)条件下,研究了不同根际细菌和藻类处理(B0-对照、B1-脂质偶氮螺菌、B2-巨芽孢杆菌、B3-嗜糖小球藻)对药用植物几种生理生化参数的影响。结果表明,施用不同种类的根瘤菌和藻类对缓解有限的灌溉胁迫具有积极作用。此外,不同生理生化参数的范围数值,包括叶片相对含水量(RWC)、叶片组织离子渗漏量(ILLT),膜耐受指数(MEI)、叶绿素含量、氮平衡指数、丙二醛(MDA)、总抗氧化活性、总酚含量和总黄酮含量分别为61.8-77.2%、29.2-42.8%、57.2-68.9%、26.8-38.2µg cm-2、110.6-158.0 mg g-1、0.276-573.0 nmol g-1、19.92-55.92 Mmol TE g-1、27.37-68.75 mg GAE g-1和9.49-分别为17.88 mg QE 100 g-1。结果表明,在土耳其干旱和半干旱地区,铁皮石斛可以作为一种抗旱植物进行商业栽培
关键词:万寿菊、金盏花、干旱胁迫、根际细菌。
Effects of rhizobacteria and algal species on physiological and biochemical parameters in Calendula officinalis L. under different irrigation regimes
Abstract
Drought is one of the main limiting factors affecting the growth and productivity of plants.
Drought stress affects plant growth in different ways through a series of anatomical, morphological, physiological and biochemical changes. Therefore, it is important to develop alternative methods to protect plants against drought stress. Turkey has one the most unique cultivated areas of different medicinal and aromatic plants including Calendula officinalis. Despite its considerable importance and use as a medicinal plant, its commercial production is very limited. In this study, the effects of different rhizobacteria and algal species treatments (B0 –control, B1 –Azospirillum lipoferum, B2 –Bacillus megaterium, B3 –Chlorella saccharophila) on several physiological and biochemical parameters in C. officinalis were studied under irrigation regimes –normal irrigation (K1 ), 50% irrigation (K2 ) and 25% irrigation (K3 ). The results showed that the application of different rhizobacterial and algal species had positive effects by reducing the limited irrigation stress. Also, the range of different physiological and biochemical parameters
values, including leaf relative water content (RWC), ion leakage in leaf tissues (ILLT),
membrane endurance index (MEI), chlorophyll content, nitrogen balance index, MDA, total antioxidant activity, total phenolic content and total amount of flavonoids were determined as 61.8-77.2%, 29.2-42.8%, 57.2-68.9%, 26.8-38.2 µg cm-2, 110.6-158.0 mg g-1, 0.276-573.0 nmol g-1, 19.92-55.92 Mmol TE g-1, 27.37-68.75 mg GAE g-1and 9.49
-17.88 mg QE 100 g-1, respectively. The results revealed that C. officinalis could be commercially cultivated as a drought-resistant plant species in arid and semi-arid regions of Turkey.
Keywords: marigold, Calendula officinalis L., drought stress, rhizobacteria.
相关阅读
PESSL便携式便携式植物多酚-叶绿素仪原理
Dualex植物多酚-叶绿素仪:腐殖酸通过铁依赖和非铁依赖的协同机制缓解禾本科植物的铁失绿症
Dualex植物多酚-叶绿素仪:硝化抑制剂和/或间作效应下玉米(和小麦灌溉种植系统中的硝酸盐淋失
Dualex植物多酚-叶绿素仪:与保持绿色表达相关的叶片和冠层性状与对水分胁迫具有不同耐性的小麦基因型的产量构成密切相关
Dualex植物多酚-叶绿素仪:基于地面和智能传感器的冬小麦营养营养仪
利用Pessl叶绿素仪植物多酚Dualex发表过的文章
博普特圆满参展2024中国园艺学会
博普特合作伙伴Videometer参加ISTA成立100周年种子会议
科学家利用博普特合作伙伴Videometer的多光谱成像系统发表糖衣替代物研究文章
