Videometer种子表型组学:种子质量研究新工具
高生理质量的种子取决于其优越的发芽能力和均匀的幼苗形成。本文研究了多光谱图像与机器学习模型相结合能否有效地对花生种子的品质进行分类。传统上,通过多光谱图像(面积、长度、宽度、亮度、叶绿素荧光、花青素和反射率:365至970 nm)评估七批种子的质量(种子重量、含水量、发芽率和活力)。评估每批种子的幼苗的光合能力(荧光和叶绿素指数、F0、Fm和Fv/Fm)和胁迫指数(花青素和NDVI)。人工智能特征(QDA方法)应用于从高质量和低质量的种子图像中提取的数据。低质量种子的幼苗叶片中花青素含量较高。因此,这一信息是有价值的,因为幼苗的初始行为反映了种子的质量。证实了有效筛选花生种子品质的新标记的存在。物理特性(面积、长度、宽度和外壳亮度)、色素(叶绿素荧光和花青素)和光反射率(660、690和780 nm)的组合可以高效地识别品质优良的花生种子地块(准确率98%)。
An Approach Using Emerging Optical Technologies and Artificial Intelligence Brings New Markers to Evaluate Peanut Seed Quality
Seeds of high physiological quality are defined by their superior germination capacity and uniform seedling establishment. Here, it was investigated whether multispectral images combined with machine learning models can efficiently categorize the quality of peanut seedlots. The seed quality from seven lots was assessed traditionally (seed weight, water content, germination, and vigor) and by multispectral images (area, length, width, brightness, chlorophyll fluorescence, anthocyanin, and reflectance: 365 to 970 nm). Seedlings from the seeds of each lot were evaluated for their photosynthetic capacity (fluorescence and chlorophyll index, F0, Fm, and Fv/Fm) and stress indices (anthocyanin and NDVI). Artificial intelligence features (QDA method) applied to the data extracted from the seed images categorized lots with high and low quality. Higher levels of anthocyanin were found in the leaves of seedlings from low quality seeds. Therefore, this information is promising since the initial behavior of the seedlings reflected the quality of the seeds. The existence of new markers that effectively screen peanut seed quality was confirmed. The combination of physical properties (area, length, width, and coat brightness), pigments (chlorophyll fluorescence and anthocyanin), and light reflectance (660, 690, and 780 nm), is highly efficient to identify peanut seedlots with superior quality (98% accuracy).
相关阅读
Videometer种子表型组学:种子活力研究-荧光成像
植物病害表型组学:多光谱病害指纹图谱
Videometer种子表型组学:多光谱成像作为菠菜种子健康检测的潜在工具
Videometer种子表型组学:多光谱图像分析在种子种质库管理中的应用
Videometer种子表型组学:利用可见光、近红外多光谱和化学计量学对不同番茄种子品种的分类
Videometer种子表型组学:使用多光谱成像和化学计量学方法在线鉴别水稻种子
Videometer种子表型组学:使用多光谱成像预测蓖麻种子的活力
Videometer种子表型组学:甜菜种子加工损伤的多光谱图像分类
种子表型组学:基于多光谱成像的葵花籽品质特征识别
种子表型组学:利用多光谱成像和化学计量学方法对大豆种子进行无损鉴别
种子表型组学:Videometer多光谱成像种子质量评估的新工具
种子表型组学:聚合物包衣对水稻种子萌发的影响
种子表型组学:基于可见-近红外多光谱图像数据的偏最小二乘判别分析检测菠菜种子的发芽能力和胚芽长度
种子表型组学:使用灰度共生矩阵和机器学习技术识别单倍体玉米种子
种子表型组学:不同成熟度甜菜种子发芽抑制因子去除的优化
种子表型组学:通过射线照相和多光谱图像分析测定小麦种子中的侵染
种子表型组学:用于表征麻疯树种子质量的多光谱和X射线图像
种子表型组学:盐胁迫下九个高羊茅品种的种子萌发和幼苗生长参数
种子表型组学:多光谱成像结合机器学习判别辣椒种子品种
种子表型组学:叶绿素荧光作为花生种子品质评价的新标志物
种子表型组学:基于多光谱和共振成像技术的麻疯树种子健康分析新方法
种子表型组学:多光谱成像结合多变量分析的单株紫花苜蓿种子品种鉴别
基于机器学习和多光谱成像分类的茄子种子分类方法研究
种子表型组学:通过多光谱成像分析对自然老化的紫花苜蓿种子进行无损鉴定
种子表型组学:自动荧光光谱成像作为一种快速、无损和可靠地评估大豆种子质量的创新方法
阅读59次
最新动态
推荐产品
当前位置: 博普特 动态 Videometer种子表型组学:种子质量研究新工具
