Dualex植物叶绿素仪应用大豆干旱胁迫研究
Dualex是一款源自于法国国家科学院 (CNRS)及巴黎第十一大学技术,由奥地利PESSL公司生产(原法国Force-A公司)开发的新型多功能叶片测量仪。它可同时准确测量叶片的叶绿素含量、叶片表层的类黄酮和花青素含量,适用于植物生理学和农学(如水稻叶绿素浓度,玉米氮素状况,葡萄藤等)相关研究。
其测量对象可以是单子叶植物,双子叶植物或多年生植物。这款设备简单易用,可进行实时和非破坏性测量。由于不需要校准标定和事先的样品制备,测量工作可在实验室或现场完成。此外,该设备在各种温度的和环境光照条件下均可正常使用。系统采用专利设计,光学传感器可进行简单、快速、无损测量叶片中的叶绿素、多酚以及花青素。
Dualex便携式智能气象-叶绿素-花青素-黄酮醇测量仪
摘要
背景:本研究旨在研究根际细菌和蓝藻对水分胁迫下生长的大豆(Glycina max L.)某些生理特性的影响。
方法:采用随机区试设计,按阶乘顺序进行4次重复试验。在研究中,使用了属于大豆(Glycine max L.)物种的Arý大豆品种。本试验旨在研究三种不同灌溉水平(100%、50%和25%)对大豆某些生理特性的影响,其中对照组(B0)使用两种不同的细菌。在本研究中,使用了脂质偶氮螺菌R1菌株、巨大芽孢杆菌属98号菌株和一种蓝绿藻(嗜糖小球藻)。
结果:根据获得的平均数据,根长24.75cm-30.85cm,幼苗长28.10-36.57cm,根鲜重1.10-1.43g,幼苗湿重1.55-2.41g,根干重0.15-0.18g,幼苗干重0.38-0.46g,亚硝酸盐平衡指数70.64-82.90(dualex值),黄酮醇0.375-0.398(dualex值),花青素0.016-0.045(dualex值),在水分限制的情况下,这些值中的大多数都有所降低。已经确定,根际细菌和蓝藻对所检测的生理特性具有降低和调节作用。
关键词
干旱胁迫,大豆,根瘤菌,耐性
The Effect of Rhizobacteria in the Reducing drought Stress in Soybean (Glycine max L.)
Abstract
Background: This study was carried out to determine the effects of rhizobacteria and blue green algae applications on some physiological properties of soybean (Glycina max L.) grown under water stress.
Methods: The experiment was conducted in factorial order with 4 replications according to the randomized plot trial design. In the research, Arýsoy variety belonging to soybean (Glycine max L.) species was used. In the experiment, it was aimed to examine the effects of three different irrigation levels (100, 50 and 25%) on some physiological characteristics of soybean with a control (control (B0), two different bacteria used. In this study, strains R1 of Azospirillum lipoferum bacteria, strains numbered 98 belonging to Bacillus megaterium bacteriaein and one blue green algae (Chlorella saccharophilia) were used.
Result: According to the average data obtained, root length is 24.75 cm- 30.85 cm, seedling length 28.10-36.57 cm, root fresh weight 1.10-1.43 g, seedling wet weight 1.55-2.41 g, root dry weight 0.15-0.18 g, seedling dry weight 0.38-0.46 g, azote balance index 70.64-82.90 (dualex value), flavonol 0.375-0.398 (dualex value) and anthocyanin 0.016-0.045 (dualex value), with water restriction showed a decrease in most of these values. It has been determined that the rhizobacteria and blue-green algae have a decreasing and regulating effect on the physiological properties examined.
KeywordsDrought stress Rhizobacteria Soybean Tolerance
北京博普特科技有限公司是奥地利PESSL系列产品中国区总代理,全面负责其系列产品在中国市场的推广、销售和售后服务
阅读24次
最新动态
推荐产品
当前位置: 博普特 动态 Dualex植物叶绿素仪应用大豆干旱胁迫研究
