资料下载Multiple Reaction Monitoring (MRM) mode has become the preferred method for the quantitative analysis of known or target compounds using triple quadrupole mass spectrometry.The current solution for MRM analysis uses time segmentation, where a method is divided into a series of time segments and predefined sets of MRM transitions are monitored for each segment. As sample complexity increases (e.g. quantifying very low levels of hundreds of pesticide residues in a wide variety of food matrices), very real practical limitations in the time-segmentation methodology become apparent. A better solution is required. New dynamic MRM methods on the Agilent 6400 Series triple quad instruments create new capability to tackle large multi-analyte assays and to accurately quantify exceedingly narrow peaks from fast Agilent 1200 Series RRLC and 1290 Infinity UHPLC separations. Examples of pesticide analysis and rapid screening of drugs of abuse are highlighted. Dynamic MRM methods yield equivalent, or better, quality data and results as compared to traditional time segment based methods – plus easier method development and modification.
用于多用户实验室的 Agilent 6120B 单四极杆 Walk-up
简介:药物发现和开发期间,需要可靠且易用的仪器进行化合物鉴定和纯度检查。Agilent 6120B 单四极杆硬件和软件是在多用户环境中支持 Walkup LC/MS 方法分析小分子和生物分子的理想选择。简洁的软件界面与稳定耐用的硬件结合,让非专家用户也可以自信地执行高质量且可靠的 LC/MS 分析。AgilentMassHunter Walkup 软件提供自动电子邮件报告,用户坐在办公桌旁就可以接收到条理清晰的结果。本应用简报讨论了 6120B 单四极杆 Walkup 系统的主要硬件和软件功能,以及包括化学品库分析等应用中的实际使用。
Agilent 1260 Infinity 纯化系统 — 无限卓越的回收率和纯度 (PDF)
简介:Agilent 1260 Infinity 纯化系统 — 无限卓越的回收率和纯度 (PDF)
Agilent 1260 Infinity 低流速液相色谱系统 — 无限卓越的毛细液相色谱和纳流液相色谱 (PDF)
简介:Agilent 1260 Infinity 低流速液相色谱系统 — 无限卓越的毛细液相色谱和纳流液相色谱 (PDF)
Agilent 7697A 顶空进样器 (PDF)
简介:Agilent 7697A 顶空进样器 (PDF)
Agilent 7693A 系列自动液体进样器产品样本 (PDF)
简介:Agilent 7693A 系列自动液体进样器产品样本 (PDF)
二手翻新agilent安捷伦1200液相色谱仪
二手翻新安捷伦1260液相色谱仪
二手翻新安捷伦6890气相色谱仪
二手翻新agilent安捷伦7683自动进样器(带塔和盘)
二手翻新agilent安捷伦7890A气相色谱仪
二手翻新agilent安捷伦7890B气相色谱仪
二手翻新agilent安捷伦1329自动进样器
故障仪器寄修
二手翻新agilent安捷伦5973质谱仪
二手翻新agilent安捷伦5975质谱仪
二手翻新agilent安捷伦7697顶空进样器
二手翻新waters沃特世2695液相色谱仪
二手翻新agilent安捷伦7694顶空进样器
二手翻新agilent安捷伦G1888顶空进样器
二手翻新agilent翻新液相色谱HTS/HTC进样器
