方案下载应用领域 | 生物产业 |
检测样本 | 生物发酵 |
检测项目 | |
参考标准 | 发酵罐在毕节酵母菌培养中的应用 |
酵母菌是一种单细胞的真核微生物。酵母菌是个通俗名称,是以芽殖或裂殖来进行无性繁殖的单细胞真菌的统称,与以霉菌区分开。极少数种可以产生子囊孢子进行有性繁殖。酵母菌主要分布在含糖质较高的偏酸性环境,如各种水果的表皮、发酵的果汁、蔬菜、花蜜、植物叶面、菜园果园土壤和酒曲中。他们多为腐生菌,少数为寄生菌,能引起人和植物的病害,有的酵母菌可与昆虫共生。
发酵罐在毕节酵母菌培养中的应用
Fermenter System for P. pastoris culture.
The fermenter is supplied in a configuration to provide an excellent bioreactor for this purpose.
* Powerful, top drive system with lubricated mechanical seal (magnetic options for Techfors)
* Jacketed system for efficient heat transfer.
* High-accuracy pumps for addition of pH control reagents, antifoam and feed (option on some units)
* Control of dissolved oxygen by stirrer speed as standard (air flow, pressure & oxygen, supplement options)
* Optional analogue feed pump for variable speed additon
* Analogue input/output for addition of external pumpsand sensros for eg. OD and Methanol
Vessels:
All vessels are stainless steel (1.4435) with a dished base and top plate in several standard sizes. Temperature control can be by water circulation with either a heating element or steam injection into a pocket/exchanger.
All vessels are with a mechanical seal drive (magnetic coupling for cells). The drive shaft has a simple and secure connection for the motor. The top plate is equipped with 10mm, PG13.5 and standard, rounded -thread 19mm ports which can be fitted with a septum and retaining collar to allow flaming of the port during inoculation etc. (number and type varies according to specific fermenter). Bottom ports are 25mm Ingold standard and numbers vary by size.
The vessels are sterilized in situ (Techfors and Techfors S) with automatic sequencing. Reagent bottles and inlet pipes etc are usually autoclaved separately (options & alternatives, depending on size and configuration)..
Stirring
The fermenter has a powerful brushless motor with integral speed controller for speeds from 100 - 1500 rpm, depending on the vessel size and number of impellors. Powerful fluid cooled motors are standard for Techfors.
x-DDC Control System:
All fermenter models except Minifors incorporate the x-DDC (eXtended DDC microprocessor control) which uses a high-performance digital system. With the use of almost identical instrumentation, the step from Bench-scale to larger equipment is made considerably easier.
The control panel is compact and is usually mounted above the base unit for clear visibility. The panel can be removed if required. Programming of parameters is via a splashproof keypad with a rotary knob for navigation and an LCD display. Communication is via a robust data-cable. For each fermenter, process information such as parameter set points, PID values etc are stored automatically on an interchangeable "memory card" . This allows changes in fermentation processes by fitting an alternative card or downloading a recipe without re-programming and the chance of errors plus an unlimited number of recipes to be stored.
An "open frame" gas supply system with four magnetic valves allow addition of components for automatic mixing of gasses for oxygen supplementation. An optional mass flow control valve ensures a controlled, steady flow of gas into the vessel. Agitation & temperature control. Four high-accuracy digital peristaltic pumps supplied as standard with the option to add an integral analogue feed pump. Addition and removal of liquids is therefore possible with a standard system (using the antifoam pump for medium take-off). Accepts a conductive probe for automatic control of antifoam addition or media addition/removal in a vessel. Works together with the integral peristaltic pumps.
摇床振幅如何正确选择?
振荡在生物培养中的作用
箱体分舱段,培养条件更稳定
博奥思 BioBench Lux 平板LED光照反应器
博奥思 BioUniv 台式生物反应器
博奥思 BioBench Twin 双位平行反应器
博奥思 BioBench 台式原位灭菌生物反应器
博奥思 BioTwin 中试原位灭菌生物反应器
博奥思 BioPilot 大型原位灭菌发酵系统
博奥思 BioR 细胞生长实时监控系统
博奥思 Pharm X / S /5制药振荡培养箱
博奥思 C7/C5/C3 多功能细胞培养振荡培养箱
博奥思 C5 多功能细胞培养振荡培养箱
博奥思 C3 多功能细胞培养振荡培养箱
博奥思 PharmS 制药振荡培养箱
博奥思 Pharm7 制药振荡培养箱
博奥思 Pharm5 制药振荡培养箱
博奥思 Thermotron 高温振荡培养箱
