PHENOM POROMETRIC SOFTWARE MAIN ADVANTAGES PHENOM PoROMETRIC SOFTWARE FULLY AUTOMATED MEASUREMENTS OF PORES PHENOM POROMETRIC Easy visualisation of statistical pore data REPORTING TOOL Integrated software in Pro Suite AUTOMATED MEASUREMENTS The visualization and analysis of pores are easier than ever before with the Phenom desktop SEM and the PoroMetric software.The combination of speed, ease of use and superb imaging quality of the Phenom and image pore analysis software of PoroMetriccreates a powerful tool for inspecting a wide range of samples like filters and membranes. POROMETRIC SOFTWARE The Phenom desktop SEM with PoroMetric software allowseasy generation and analysis of SEM images. The integratedPoroMetric software allows the user to gather data ondistribution of pores, and pore parameters like pore size andaspect ratio.The fully automated measurements of PoroMetric allow a levelof visual exploration beyond optical microscopy that can leadto new discoveries and innovations. The histogram andgenerated images can be exported in the selected format to beused as a reporting tool. PORE ANALYSIS GRAPHICAL DISPLAY Plot graphs of the circle equivalent Pore size range 100nm-0,Imm diameter, SEM images and detected pores Pore detection speed Up to 1000 pores per minute OuTPUT Report in docx format Measured properties Size,shape, count TIFF image format CSV file PORE PARAMETERS Area, circle equivalent diameter, aspect ratio, major axis, minor axis and manual Project file (.POME) for offline analysis measurement PART OF PRO SUITE Network storage enabled Phenom integraded system PoroMetric allows the user to get a better understanding ofthe characteristics of the materials, as it extracts detailedinformation of the complete set of pores. PoroMetric is thefirst in its class when it comes to measurements of pores.This results in valuable information on the effects whichchanging the pore structure has on the porosity and filtrationprocess. MAIN ADVANTAGES OFTHE POROMETRICSOFTWARE >Integrated software in Pro Suite > Acquire images directly from the Phenom desktop SEM > Correlate pore features such as area, aspect ratio,major andminor axis >Fast and convenient operation improves workflow and makesscheduling simple and predictable > Image collection is limitless as digital files are easily stored ona network or USB disk for data sharing, communication, orlater reference > The Phenom’s ease of use and ability to operate in any environment means anyone can use it to visually interpret a wide range of samples > Statistical data with high-quality images. MARKETS &APPLICATIONS The Phenom desktop SEM and PoroMetric software applicationare easy to use and allow the user to extract the best results.Companies that will benefit the most from PoroMetric can befound in the: > Filter- and sieve industry > Foam industry > Ceramic industry > Pharmaceutical industry > Non woven industry ParticleMetric PARTICLEMETRIC SOFTWARE The Phenom desktop SEM with ParticleMetric software allowseasy generation and analysis of SEM images. The integratedParticleMetric software allows the user to gather morphologyand particle size data for many submicron particle applications.The fully automated measurements of ParticleMetric allow alevel of visual exploration beyond optical microscopy that canlead to new discoveries and innovations in powder design,development, and quality control. PARTICLEMETRIC SPECIFICATIONS PARTICLE ANALYSIS Particle size range 100nm-0,Imm Particle detection speed up to 1000 particles per minute Measured properties: size, shape, count PARTICLE PARAMETERS Area, circle equivalent diameter, surface area,circumscribed circle diameter, volume by area,circumference, aspect ratio, circularity,elongation, grayscale, major axis, minor axis, convex hull, gravity centre (x,y), pixel count, convexity. GRAPHICAL DISPLAY Plot graphs in linear log or double log scale,by number or by volume Scatter plots of any given parameter SEM image of individual particle FiberMetric FIBERMETRIC SOFTWARE The FiberMetric application allows you to produce accurate sizeinformation from micro and nano fiber samples. It is possible tomeasure and analyse complicated fiber structures, ranging fromspunbond and electrospun fibers to the melt blown type fibers.FiberMetric automatically analyses hundreds of data points thatprovide solid statistical analysis. This data is displayed in variousformats like an interactive fiber and pore size distributionhistogram. All data are exportable to common formats foroffline customized analysis. FIBERMETRIC SPECIFICATIONS FIBER DETECTION 40 pm to 100 nm I to 1000 measurements per image OUTPUT IXML-data file (incl. diameter measurements and pore surface areas) Jpg or tiff image format Max. 1024×1024 pixel image Customized fiber and pore distribution histogram Minimum, maximum and average fiber size Standard deviation Fiber orientation PART OF PRo SuITE Network storage enabled Phenom integrated system PHENOM POROMETRICSPECIFICATION SHEET SPECIFICATION SHEET
关闭还剩2页未读,是否继续阅读?
复纳科学仪器(上海)有限公司为您提供《飞纳台式扫描电镜中孔径分析系统检测方案 》,该方案主要用于其他中其他检测,参考标准《暂无》,《飞纳台式扫描电镜中孔径分析系统检测方案 》用到的仪器有飞纳台式扫描电子显微镜专业版Pro、飞纳台式扫描电子显微镜标准版 Pure、飞纳台式扫描电镜。
