检测样品 等离子体
检测项目 表面等离子体共振仪(SPR)专用流体池
金牌会员 752 篇解决方案
2 SPR FLOW CELL OPTREL GBR WWW.OPTREL.DE The SPR flow cell is custom made for the Multiskop and optimized for the adsorptionmeasurements. The cell utilizes the Kretschman configuration (excitation of surface plas-mona via a prism). The design of prism clamp maximizes the accessible angle range ofthe reflection scans and ensures that the beam is not chopped off. Cell and cover are made of a special aluminium alloy with a black anodised surface. Celland cover can be hooked up to a laboratory thermostat for a reproducible temperaturewithin the cell. The cell has a inlet and outlet which should be hooked up to a peristaltic pump containingvour solution of interest. Please note: Adsorption measurement require special prism with a high refractive indexsuch as LASF9 (n=1.84).Prism, thermostat or peristaltic pumps are not part of thisoffer. OPTREL GBR·StraBe der Jugend 27-29 14532 Kleinmachnow · www.Optrel.de·optrel@t-online.de
关闭产品配置单
北京欧兰科技发展有限公司为您提供《等离子体中表面等离子体共振仪(SPR)专用流体池检测方案(其他生物/生化分析仪)》,该方案主要用于等离子体中表面等离子体共振仪(SPR)专用流体池检测,参考标准《暂无》,《等离子体中表面等离子体共振仪(SPR)专用流体池检测方案(其他生物/生化分析仪)》用到的仪器有表面等离子共振仪(SPR)(Surface Plasmon Resonance)、LaVision HighSpeedStar 高帧频相机、德国LaVision PIV/PLIF粒子成像测速场仪。
