类鱼雷形涡中速度场,速度矢量场,PIV,粒子成像测速检测方案(粒子图像测速)
检测样品
其他
检测项目
关联设备
共2种
下载方案
The flow field of a laboratory-simulated tornado was studied by means of 2-D Particle
Image Velocimetry or PIV technique with the purpose of investigating the effects of roughness on
the near-ground tornado-like vortex structure and its velocity distribution. The results show the flow
regime transition from multi-celled vortices over the smooth surface at a higher swirl ratio to singleor
dual-celled vortices with roughness. Significant difference in velocities and turbulence
characteristics is observed as a result of increasing ground roughness. This work is part of a project
that seeks better understanding of the near-ground flow field and resulting wind-induced loads on
structures in a tornado.
北京欧兰科技发展有限公司为您提供《类鱼雷形涡中速度场,速度矢量场,PIV,粒子成像测速检测方案(粒子图像测速)》,该方案主要用于其他中速度场,速度矢量场,PIV,粒子成像测速检测,参考标准《暂无》,《类鱼雷形涡中速度场,速度矢量场,PIV,粒子成像测速检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、Imager sCMOS PIV相机。
我要纠错
