高压燃烧系统,氮氧化物中激光诱导荧光,PLIF,自由基,羟基,浓度场检测方案(流量计)
检测样品
其他
检测项目
关联设备
共3种
Practical diagnostic strategies for detection of temperature and nitric oxide (NO) in high pressure (p<60bar) combustion systems using Laser-Induced-Fluorescence (LIF) of nitric oxide are investigated. NO-LIF, when applied to elevated pressures, suffers from a decrease of signal due to pressure broadening and attenuation of the propagating laser beam/fluorescence signals. In addition, overlapping of neighboring excitation lines and interference from LIF of other species (mainly O2 and CO2) can significantly influence the overall signal. The main purpose of this study is to investigate NO-LIF strategies which minimize the impact of these complications or allow for correction of their effects. A comprehensive study of NO-LIF in a laboratory high-pressure flame was carried out for various flame stoichiometries, pressures and excitation wavelengths to develop optimized excitation and detection strategies for high-pressure applications. Four main issues are addressed in this study. First, optimized excitation strategies are investigated for high-pressure applications in the A2Σ+−X2Π (0,0), (0,1) and (0,2) bands of NO. Second, CO2-LIF is identified as a major source of interference in the detection of NO-LIF in high-pressure combustion systems involving hydrocarbon chemistry. Third, an accurate multi-line thermometry technique for steady, high-pressure flames is proposed by fitting wavelength-scanned NO-LIF with computational simulations. Finally, measurements optimizing the detection strategies of 2-D NO-LIF imaging in high-pressure flames are reported. The discussion and demonstrations reported in this study provide a practical guideline for application of instantaneous 1-D or 2-D NO-LIF imaging in high-pressure combustion systems.
北京欧兰科技发展有限公司为您提供《高压燃烧系统,氮氧化物中激光诱导荧光,PLIF,自由基,羟基,浓度场检测方案(流量计)》,该方案主要用于其他中激光诱导荧光,PLIF,自由基,羟基,浓度场检测,参考标准《暂无》,《高压燃烧系统,氮氧化物中激光诱导荧光,PLIF,自由基,羟基,浓度场检测方案(流量计)》用到的仪器有PLIF平面激光诱导荧光火焰燃烧检测系统、德国LaVision PIV/PLIF粒子成像测速场仪、时间分辨平面激光诱导荧光测量系统。
我要纠错
