检测样品 其他
检测项目 Reference 3000阻抗
银牌会员
20 篇解决方案
Gamry Instruments Accuracy of 1 G Ohm at 0.1 Hz with Gamry Reference 3000 In order to confirm that the accuracy of 1G Ohm measurement at 0.1 Hz for Gamry Reference3000 is better than 0.3%, the following experiment is designed and carried out at Gamryinstruments, USA on May-10, 2016. Experiment setup: Resistor: 2 pieces of 2 GOhm with a parallel connection for 1 G Ohm resistor. EIS measurement at 0.1 Hz. The setup of EIS measurement is given as the following, 0.2 hr (12 min) of measurement at 0.1Hz, Data and plot are given as the following. Gamry Instruments EIS result and accuracy of 1 GOhm ofresistor: 1 GOhm of resistor is measured and the following values are given, 15 impedance data areacquired with an error less than 0.1%. ZCURVE (EISMON1Gb.DTA) Time (sec)Impedance(Ohm)0.000e+0009.999e+0086.200e+0019.999e+0081.340e+0021.000e+0091.960e+0029.999e+0082.790e+0021.000e+0093.250e+0021.000e+0093.710e+0021.000e+0094.170e+0021.000e+0094.630e+0029.999e+0085.090e+0021.000e+009 Gamry Instruments 5.550e+002 1.000e+009 6.010e+002 1.000e+009 6.470e+002 1.000e+009 6.930e+002 1.000e+009 7.390e+002 1.000e+009 Conclusions: The performance and accuracy of Gamry Reference 3000 in impedance measurement of 1GOhm is better than 0.1% in the deviation, which is based on the actual measurement. Louis Drive, Warminster, PA Fax info@gamry.com www.gamry.comPage 美国Gamry公司Reference 3000电化学工作站主要功能及特点美国Gamry公司最新型号电化学工作站,保留了以往型号所有的优势;卓越的低阻抗测试特性,准确度到达微欧数量级。为能源材料研究特别改进了硬件和软件,电流量程3pA-3A,可以扩展到30A,电压最高32V,300K的采样速度,电浮动浮地技术;特别为电池,电容器,液流电池等能源材料设计的PWR800软件测试包等等。可以进行系列电化学测试编程。同时可以扩展位双恒电化学工作站和IMPS/IMVS系统。Reference 3000 可以使用Gamry所有的电化学软件进行电化学领域的研究: >合成化学 >传感器的研发 >动力学,热力学研究 >电化学阻抗 >腐蚀 >涂层 >电分析Reference 3000电化学工作站在能量储存和转换方面的研究领域具有独特的表现。例如: 电池,燃料电池,超级电容。 >特别设计的“stack mode”可以进行32V电压测量和控制。 >两档电压和电流设置:(±32 Volts at ±1.5 Amps 和 ±15 volts at ±3.0 Amps) >可以在恒电位或恒电流模式下进行EIS测试。 其中在杂化电流模式下,每个频率段的交流电流通过动态调整达到一个固定的交流电压输出。 >辅助电位计选件,可以同时进行八个不同电压源的测试。 >低阻抗电极引线选件,可以很好地测量到100欧姆的阻抗。 >电池充放电过程中,从恒电流到恒电压的转换不会有任何脉冲干扰。Reference 3000 串联八通道的最大输入电压为仪器的的最大槽压(±32 V 或 ±15 V)Reference 3000输入阻抗大于10G欧姆,所以可以连接很小的高阻抗的参比电极。或者小面积的Luggin检测器。 串联八通道选件的主要功能是同时测量每一个组件的电压,阻抗(如电池组,燃料电池和超级电容)。由于串联的原理,电流通过每一个组件是相同的。Reference 3000 可以获得此电流的大小,通过每个通道测到的电压便可以表征每个组件的电化学性能了。 每个通道有独立的偏置设置,增益设置和滤波器。交流阻抗方法可以测试±50 mV 的范围。串联八通道选件也可以用于测量温度传感器,压力传感器或应变传感器上的电压值,或者测量多个参比电极的电压。Reference 3000电化学工作站主要技术参数 >最大输出电流:±3A >最大输出电压:±32V >电位范围:±32V >电位分辨率:1 μV >电流范围:3A、300mA、30mA、3mA、300μA,30μA、3μA、300nA、30nA,3 nA, 300 pA共十一个档; 外扩充两个低电流挡, 30 pA和3 pA. >电流精度:±10 pA或电流范围值±0.3% >电流分辨率:100 aA >输入偏差电流:<10 pA 浮地式恒电位仪应用举例 >高温高压釜联用 >土壤中金属构件的腐蚀研究 >海水中的腐蚀研究 >桥梁的腐蚀研究 >摩擦腐蚀 >与透射电镜的联用Reference 3000 主要指标: >电流档,从皮安级到3安培,自动改变范围 >模拟和数字滤波 >1 MHz 交流阻抗 >电子与大地绝缘 >电流中断的iR 补偿 >采样速度: 300,000 points/sec 独特的数字信号处理系统,保证了Reference3000能够有效的消除来自设备,电化学池子和实验室环境的噪声干扰。Reference 3000 通过USB和电脑连接。 辅助电压计选件 Reference 3000 提供一个串联的八通道电位计选件。此选件特别适用于测量几个串联在一起的电池组。配备此选件后的Reference3000的实物图如下:每一个通道可以测试独立的电压,所以在电池组中的每一点电压都可以独立测量。
关闭还剩2页未读,是否继续阅读?
北京亿诚恒达科技有限公司为您提供《电阻(Gmary电化学工作站)中Reference 3000阻抗检测方案(电化学工作站)》,该方案主要用于其他中Reference 3000阻抗检测,参考标准《暂无》,《电阻(Gmary电化学工作站)中Reference 3000阻抗检测方案(电化学工作站)》用到的仪器有Reference 3000AE 电化学工作站。
