铸件X射线检测的解决方案 SOLUTION OF X-RAY SYSTEM FOR TESTING CASTINGS 该方案适合于铸件内部气孔、浃渣、疏松等缺陷的无损检测。 该产品技术已获得国家专利。 This product applies to inspect all kind of casting, for example, steel casting, aluminum casting. We can use X-ray to nondestructive test faults in castings including pore, inclusion, loosen and etc. The technology of this product received the China's National patents. 系统组成: ●X射线探伤机 ●图像增强器(或线阵、平板成像器) ●图像处理系统 ●多轴检测平台 ●铅防护房 Main Configuration ●X-ray unit ●Image intensifier(or linera detector,or flat detector) ●Image processing system ●Five axes(or 7 axes) manipulator ●Lead cabinet 主要技术指标 ●管电压:20kV~450kV ●管电流:0.1mA~20mA ●重复精度:±0.01% ●高压上升时间:0.1ms~0.3ms ●系统分辨率:16Lp/cm~39Lp/cm ●灵敏度:1.2%~1.5% Main Parameters ●Tube voltage: 20 kV ~450kV ●Tube current: 0.1 mA ~20mA ●Repeatability precision:±0.01% ●High voltage rising time: 0.1 ms ~0.3ms ●System resolution: 16 LP/cm ~39LP/cm ●Sensitivity: 1.2%~1.5% 铸件X射线检测的解决方案SOLUTION OF X-RAY SYSTEM FOR TESTING CASTINGS 该方案适合于铸件内部气孔、浃渣、疏松等缺陷的无损检测。该产品技术已获得国家专利。 This product applies to inspect all kind of casting, for example, steel casting, aluminum casting. We can use X-ray to nondestructive test faults in castings including pore, inclusion, loosen and etc. The technology of this product received the China's National patents. 系统组成:●X射线探伤机●图像增强器(或线阵、平板成像器)●图像处理系统●多轴检测平台●铅防护房 Main Configuration●X-ray unit●Image intensifier(or linera detector,or flat detector)●Image processing system●Five axes(or 7 axes) manipulator●Lead cabinet 主要技术指标●管电压:20kV~450kV●管电流:0.1mA~20mA●重复精度:±0.01%●高压上升时间:0.1ms~0.3ms●系统分辨率:16Lp/cm~39Lp/cm●灵敏度:1.2%~1.5% Main Parameters●Tube voltage: 20 kV ~450kV ●Tube current: 0.1 mA ~20mA●Repeatability precision:±0.01%●High voltage rising time: 0.1 ms ~0.3ms●System resolution: 16 LP/cm ~39LP/cm●Sensitivity: 1.2%~1.5%
关闭产品配置单
丹东奥龙射线仪器集团有限公司为您提供《铸件中铸件内部气孔、浃渣、疏松等缺陷的无损检测检测方案(实时成像检测)》,该方案主要用于铸件中铸件内部气孔、浃渣、疏松等缺陷的无损检测检测,参考标准《暂无》,《铸件中铸件内部气孔、浃渣、疏松等缺陷的无损检测检测方案(实时成像检测)》用到的仪器有奥龙Aolong小铸件X射线数字成像检测系统、X射线无损检测服务、工业CT检测服务。
