原子荧光光谱测定化妆品中痕量铅 黄宗平 (厦门出入境检验检疫局 福建厦门 361012) 摘要:介绍氢化物发生—原子荧光光谱法对化妆品中铅含量的定量分析方法,并研究原子荧光光谱测定铅的分析条件。方法检出限低、精密度高、准确性好,可用于测定化妆品中的痕量铅。 关键词:原子荧光光谱;化妆品; 痕量铅 中图分类号:O657.31 文献标识码:A 文章编号: HG-AFS DETERMINATION OF TRACE AMOUNTS OF LEAD IN COSMETICS HUANG Zong-ping (Xiamen Entry-Exit Inspection and Quarantine Bureau of P. R. C., Xiamen Fujian, 361012) Abstract: The hydride generation-atomic fluorescence spectrometric method was used for the determination of trace amounts of lead in cosmetics. The sample was digested with HNO3 and H2O2. Lead(Ⅱ) ion in the sample solution was oxidized to Pb(Ⅵ) and reacted with KBH4 to generate PbH4, which was led into the atomizer, and the lead content was determined by AFS according to the optimized working conditions. A linear calibration curve with lead concentration in the range of 0.0~200.0ng·ml-1 was prepared, having a correlation coefficient of 0.9998. RSD’s of less than 1% were found at concentration levels of 19μg·g-1 and 38μg·g-1 with 11 determinations. Recoveries in the range of 96.0% to 101.5% were obtained. The detection limit achieved a value of 0.5ng·g-1, which was much lower than the value of 4μg·g-1 by AAS method. Keywords: HG-AFS; Traces of lead; Cosmetics 铅是一种重金属,在化妆品原料和成品中都有存在的可能[1]。长期接触含铅量高的化妆品易引起人体慢性铅中毒。因此铅含量作为化妆品中的一个重要卫生项目,有非常严格的限量要求[2]。目前,常采用原子吸收分光光度法进行测定[3]。本法所采用的原子荧光光谱法[4,5]检出限更低,精密度高,准确性好,方便快捷。 1 试验部分 1.1 主要仪器与试剂 AFS2201双道原子荧光光度计(北京海光仪器公司)。 盐酸羟铵溶液:120g·L-1,取盐酸羟铵12.0g和氯化钠12.0g溶于100ml水中 盐酸:3mol·L-1,取浓盐酸25ml,加水至100ml。 硼氢化钾:20 g·L-1,称取KOH 1.00g溶于200ml水中,溶解后加入KBH4 4.0g继续溶解,滤纸过滤后使用。 铁氰化钾—草酸溶液:溶解铁氰化钾20g、草酸4g于120ml水中,稀释至200ml。 铅标准溶液:1000μg·ml-1,由国家钢铁材料测试中心提供。 1.2 仪器分析条件 灯电流30mA,负高压360V,炉温800℃,原子化器高度8.0mm,读数时间10.0s, 氩气流量:载气400ml·min-1,屏蔽气800 ml·min-1,测量方法:统计测量,读数方式:峰面积。 1.3 试验步骤 1.3.1 样品前处理[6](浸提法) 称取试样约1.00g于25ml比塞管中,同时作试剂空白。加硝酸(优级纯)2ml、过氧化氢(30%)5ml,混匀(如出现大量泡沫,可滴加数滴辛醇),于沸水中加热2h;取出,加入盐酸羟铵溶液1.0ml,放置15~20min,冷却后,用去离子水定容至25ml。 1.3.2 标样系列的配制 按试验方法,用5.00μg·ml-1铅标准溶液分别加入3mol·L-1盐酸5ml,铁氰化钾—草酸溶液10ml,定容至50ml,配制成0,0.020,0.040,0.080,0.200μg·ml-1铅标样系列。 1.3.3 测定 以20 g·L-1硼氢化钾为还原剂,盐酸(1+9)为载流,根据仪器操作规程,并按仪器分析条件,测定标样系列、空白溶液及样品溶液,以荧光强度If(无单位)为纵坐标,浓度C(ng·ml-1)为横从标,绘制标准曲线。按下式计算结果 C(Pb)= (C样—C空)•V ×1000 ms 式中: C(Pb)——样品铅含量,μg·g -1 C样 ——样品溶液铅浓度,ng·ml-1 C空 ——空白溶液铅浓度,ng·ml-1 V ——定容体积,ml ms ——样品质量,g 2 结果与讨论 2.1 标准曲线线性 测定标准样品系列,绘制标准曲线,在0.0~200.0ng·ml-1 浓度范围内线性良好,曲线的相关系数为0.9998。 2.2 方法对照与检出限试验试验 本法与原子吸收光谱法测定结果对照见表1。 表1:测定结果比较(ρ/μg·g -1) Tab.1 Comparison of analytical results with those by atomic absorption spectrometry 样品 /Sample 眼影1# 眼影2# 腮红3# 色素4# 标准物质5# 1) 本方法 /This methodAAS法 /by AAS 18.8 17.8 30.2 28.9 27.6 26.5 31.5 31.2 38.2 37.5 注:1)标准值为37.9μg·g -1。 Note:1)Certified value is 37.9μg·g -1。 对0#标样进行11次实验,荧光强度平均值Average= -1.2; 标准偏差为1.46; 检出限为0.18ng·ml-1。 2.3 精密度与回收率试验 样品的精密度与回收率试验见表2和表3。 表2 样品和标准物质测定的精密度(ρ/μg·g -1) Tab.2 Precision tested by analysis of standard reference materials 样品 Sample 测定值 Found 标准偏差 Standard deviation RSD (%) 眼影1# 18.8 18.7 19.1 18.6, 19.0 18.7 18.7 18.8, 18.6 19.0 18.9 0.17 0.90 标准物质5# 37.9 38.6 37.3 38.1 38.0 37.9 38.3 38.4 38.2 38.5 38.0 0.36 0.94 表3 样品回收率试验结果 Tab.3 Results of recovery test 样品Sample 样品含量 Known content 加入量 Added am’t(m/μg) 测得值 Determined 回收率 Recovery(%) 眼影1# 25.1 25.1 24.6 10.0 20.0 30.0 34.8 45.4 53.6 97.0 101.5 96.7 色素2# 46.8 45.6 43.5 20.0 40.0 60.0 66.0 85.7 102.8 96.0 100.2 98.8 试验表明,本法方便快捷,精密度好,回收率高。 参考文献 [1] 宋国艾,杨根源,陈勉哉.化妆品原料技术标准[M].北京:中国轻工业出版社,1993.162—175,269—294. [2] 郑星泉.化妆品卫生检验[M].天津:天津大学出版社,1994.45—56. [3] 陆光崇.实用化妆品手册[M].上海:上海翻译出版公司,1988.376—378. [4] 赵藻藩,周性尧,张悟铭.仪器分析[M].北京:高等教育出版社,1988.49—54. [5] 朱良漪,孙亦梁,陈耕燕.分析仪器手册[M].北京:化学工业出版社.1997.318—328. [6] 中华人民共和国国家标准.GB7917.3—1987,化妆品卫生化学标准检验方法[S]. 作者简介: 黄宗平(HUANG Zong-ping):1972年生,籍贯福建惠安,工程师;从事化工品、化妆品、石油产品的检验分析工作。 E-mail : hzp0088@sina.com (mailto:hzp0088@sina.com) Tel.: 0592-6013202 013656022511 第1页 原子荧光光谱测定化妆品中痕量铅黄宗平(厦门出入境检验检疫局 福建厦门 361012)摘要:介绍氢化物发生—原子荧光光谱法对化妆品中铅含量的定量分析方法,并研究原子荧光光谱测定铅的分析条件。方法检出限低、精密度高、准确性好,可用于测定化妆品中的痕量铅。关键词:原子荧光光谱;化妆品; 痕量铅中图分类号:O657.31 文献标识码:A 文章编号:HG-AFS DETERMINATION OF TRACE AMOUNTS OF LEAD IN COSMETICSHUANG Zong-ping(Xiamen Entry-Exit Inspection and Quarantine Bureau of P. R. C.,Xiamen Fujian, 361012)Abstract: The hydride generation-atomic fluorescence spectrometric method was used for the determination of trace amounts of lead in cosmetics. The sample was digested with HNO3 and H2O2. Lead(Ⅱ) ion in the sample solution was oxidized to Pb(Ⅵ) and reacted with KBH4 to generate PbH4, which was led into the atomizer, and the lead content was determined by AFS according to the optimized working conditions. A linear calibration curve with lead concentration in the range of 0.0~200.0ng·ml-1 was prepared, having a correlation coefficient of 0.9998. RSD’s of less than 1% were found at concentration levels of 19μg·g-1 and 38μg·g-1 with 11 determinations. Recoveries in the range of 96.0% to 101.5% were obtained. The detection limit achieved a value of 0.5ng·g-1, which was much lower than the value of 4μg·g-1 by AAS method.Keywords: HG-AFS; Traces of lead; Cosmetics 铅是一种重金属,在化妆品原料和成品中都有存在的可能[1]。长期接触含铅量高的化妆品易引起人体慢性铅中毒。因此铅含量作为化妆品中的一个重要卫生项目,有非常严格的限量要求[2]。目前,常采用原子吸收分光光度法进行测定[3]。本法所采用的原子荧光光谱法[4,5]检出限更低,精密度高,准确性好,方便快捷。 1 试验部分1.1 主要仪器与试剂AFS2201双道原子荧光光度计(北京海光仪器公司)。盐酸羟铵溶液:120g·L-1,取盐酸羟铵12.0g和氯化钠12.0g溶于100ml水中 盐酸:3mol·L-1,取浓盐酸25ml,加水至100ml。 硼氢化钾:20 g·L-1,称取KOH 1.00g溶于200ml水中,溶解后加入KBH4 4.0g继续溶解,滤纸过滤后使用。 铁氰化钾—草酸溶液:溶解铁氰化钾20g、草酸4g于120ml水中,稀释至200ml。 铅标准溶液:1000μg·ml-1,由国家钢铁材料测试中心提供。1.2 仪器分析条件灯电流30mA,负高压360V,炉温800℃,原子化器高度8.0mm,读数时间10.0s, 氩气流量:载气400ml·min-1,屏蔽气800 ml·min-1,测量方法:统计测量,读数方式:峰面积。1.3 试验步骤1.3.1 样品前处理[6](浸提法)称取试样约1.00g于25ml比塞管中,同时作试剂空白。加硝酸(优级纯)2ml、过氧化氢(30%)5ml,混匀(如出现大量泡沫,可滴加数滴辛醇),于沸水中加热2h;取出,加入盐酸羟铵溶液1.0ml,放置15~20min,冷却后,用去离子水定容至25ml。1.3.2 标样系列的配制按试验方法,用5.00μg·ml-1铅标准溶液分别加入3mol·L-1盐酸5ml,铁氰化钾—草酸溶液10ml,定容至50ml,配制成0,0.020,0.040,0.080,0.200μg·ml-1铅标样系列。1.3.3 测定以20 g·L-1硼氢化钾为还原剂,盐酸(1+9)为载流,根据仪器操作规程,并按仪器分析条件,测定标样系列、空白溶液及样品溶液,以荧光强度If(无单位)为纵坐标,浓度C(ng·ml-1)为横从标,绘制标准曲线。按下式计算结果C(Pb)=(C样—C空)•V×1000ms式中:C(Pb)——样品铅含量,μg·g -1C样 ——样品溶液铅浓度,ng·ml-1C空 ——空白溶液铅浓度,ng·ml-1V ——定容体积,mlms ——样品质量,g 2 结果与讨论2.1 标准曲线线性测定标准样品系列,绘制标准曲线,在0.0~200.0ng·ml-1 浓度范围内线性良好,曲线的相关系数为0.9998。2.2 方法对照与检出限试验试验 本法与原子吸收光谱法测定结果对照见表1。表1:测定结果比较(ρ/μg·g -1)Tab.1 Comparison of analytical results with those by atomic absorption spectrometry样品 /Sample眼影1#眼影2#腮红3#色素4#标准物质5# 1)本方法 /This methodAAS法 /by AAS18.817.830.228.927.626.531.531.238.237.5注:1)标准值为37.9μg·g -1。Note:1)Certified value is 37.9μg·g -1。对0#标样进行11次实验,荧光强度平均值Average= -1.2; 标准偏差为1.46; 检出限为0.18ng·ml-1。2.3 精密度与回收率试验样品的精密度与回收率试验见表2和表3。表2 样品和标准物质测定的精密度(ρ/μg·g -1)Tab.2 Precision tested by analysis of standard reference materials样品Sample测定值Found标准偏差Standard deviationRSD(%)眼影1#18.8 18.7 19.1 18.6, 19.0 18.7 18.7 18.8, 18.6 19.0 18.90.170.90标准物质5#37.9 38.6 37.3 38.1 38.0 37.9 38.3 38.4 38.2 38.5 38.00.360.94表3 样品回收率试验结果Tab.3 Results of recovery test样品Sample样品含量Known content加入量Added am’t(m/μg)测得值Determined回收率Recovery(%)眼影1#25.1 25.1 24.610.0 20.0 30.034.8 45.4 53.697.0 101.5 96.7色素2#46.8 45.6 43.520.0 40.0 60.066.0 85.7 102.896.0 100.2 98.8 试验表明,本法方便快捷,精密度好,回收率高。 参考文献 [1] 宋国艾,杨根源,陈勉哉.化妆品原料技术标准[M].北京:中国轻工业出版社,1993.162—175,269—294.[2] 郑星泉.化妆品卫生检验[M].天津:天津大学出版社,1994.45—56.[3] 陆光崇.实用化妆品手册[M].上海:上海翻译出版公司,1988.376—378.[4] 赵藻藩,周性尧,张悟铭.仪器分析[M].北京:高等教育出版社,1988.49—54.[5] 朱良漪,孙亦梁,陈耕燕.分析仪器手册[M].北京:化学工业出版社.1997.318—328.[6] 中华人民共和国国家标准.GB7917.3—1987,化妆品卫生化学标准检验方法[S]. 作者简介:黄宗平(HUANG Zong-ping):1972年生,籍贯福建惠安,工程师;从事化工品、化妆品、石油产品的检验分析工作。 E-mail : hzp0088@sina.com Tel.: 0592-6013202 013656022511
关闭还剩2页未读,是否继续阅读?
北京海光仪器有限公司为您提供《化妆品中铅检测方案(原子荧光光谱)》,该方案主要用于美容/修饰类化妆品中铅检测,参考标准《暂无》,《化妆品中铅检测方案(原子荧光光谱)》用到的仪器有海光 AFS-8510 原子荧光光度计、海光 AFS-9750 原子荧光光度计。
