Application Notee c1003Eltra GmbH|Retsch-Allee 1-5|42781 Haan| Germany|Phone:+49 2104/2333-400|E-Mail:info@eltra.com|www.eltra.com C,S determinationin wood samples Suitable Analyzers CS-580 series CS-2000 (resistance furnace) Used Accessories 90160 Disposable porcelain boatsSuitable calibration material from NIST or other Settings Furnace Temperature: 1350°C Comperator level: 20 minimum analysis time: 60 seconds maximum analysis time: 180 seconds CS-2000(resistance furnace) Sample preparation For best results prepare the sample down to a particle size about 200 pm.Dry the sample till mass constancy at 105°C (in minimum for 1 Hour). Procedure Prepare and clean the ELTRA analyzer (f.e. exchange Anhydron, Sodiumhydroxide) and set the furnace temperature to 1350°C Run in minimum three warm up samples (f.e. ELTRA 92511-3020) with amedium sample weight of 200 mg until the results are stable Calibrate the system with a suitable calibration material (from NIST orother): (1) Weigh in a sample weight of 150 mg in the 90160 porcelain boots (2) Start analysis (F5 Button) (3) Load the sample into the furnace and wait until the PC calculatesresults Repeat Step (1)-(3) in minimum for three times; mark the results and usethe calibration function in the software -> Analyze the unknown samples. Please introduce the wood samples slowly into the analyzer.
关闭产品配置单
弗尔德(上海)仪器设备有限公司为您提供《木材中碳元素检测方案(红外碳硫仪)》,该方案主要用于木材/板材中碳元素检测,参考标准《暂无》,《木材中碳元素检测方案(红外碳硫仪)》用到的仪器有德国埃尔特碳氢硫分析仪Eltra CHS-r、德国埃尔特碳硫分析Eltra CS-r。
