KM KYOTO ELECTRONICSMANUFACTURING CO.,LTD.APDA-0208ov enLK-MKYOTO ELECTRONICSMANUFACTURING CO.,LTD.1/1 Application Note Determination of alcoholcontent in Polish Vodka byAlcohol meter Industry Food and BeverageInstrument Alcohol meterMeasurement method Resonant frequency oscillation 1. Scope This is an example about determination of the alcohol content (vol%), specific gravity (t/t) anddensity (g/cm3) in Polish vodka. The alcohol meter can be used enough for determination of theseapplications on the spirits making process. Technical note: The alcohol sample must be distilled as per the procedure specified on localregulations before the alcohol content can be measured with this alcohol meter. 2.Apparatus 5. Procedure A: Alcohol content (vol%): Take distilled sample solution into beakerIntroduce the sampling nozzle into the beaker)Press [Meas.] button on the instrumentB: Specific gravity (t/t) and Density (g/cm’):Take vodka sample solution into beaker)Introduce the sampling nozzle into the beaker ) Press Meas. button on the instrument 6. Measurement results Alcohol (vol%) at 20℃ S.G. (t/t) Density (g/cm’) 1 37.28 0.95478 0.95307 2 37.29 0.95480 0.95309 3 37.29 0.95482 0.95311 Mean 37.29 0.95480 0.95309 SD 0.01 0.00 0.00 RSD(%) 0.02 0.00 0.00 京都电子工业式会社-可睦电子(上海)商贸有限公司电话:021-54488867 电邮: kemu-kem@163.com 上海市徐汇区宜山路333号1201室 网址: http://www.kem-china.com 高精度酒精浓度计测定 波兰伏特加(俄得克)的酒精度(英文版) 使用高精度酒精浓度计ALM-155测定波兰伏特加(俄得克)中酒精度含量(vol%)、相对密度(t/t)和密度(g/cm3)的应用实例。高精度酒精浓度计ALM-155也可用于酿酒过程中的测量。技术说明: 样品必须按照当地规定的程序蒸馏,然后才能用此高精度酒精浓度计测量乙醇的浓度。
关闭产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《伏特加中酒精度检测方案(饮用酒检测仪)》,该方案主要用于其他酒中营养成分检测,参考标准《暂无》,《伏特加中酒精度检测方案(饮用酒检测仪)》用到的仪器有ALM-155高精度酒精度测定仪(GB 5009.225-2023)、DA-130Nc便携式密度计/比重计、DA-130N手持式数字酒精计/酒精浓度计。
