KM KYOTO ELECTRONICSMANUFACTURING CO.,LTD.APDA-0223 enLKMKYOTO ELECTRONICSMANUFACTURING CO.,LTD.1/1 Application Note Determination of alcohol content in bourbon whiskey byAlcohol meter Industry Food and BeverageInstrument Alcohol meterMeasurement method Resonant frequency oscillation 1. Scope This is an example about determination of the alcohol content (vol%), specific gravity (t/t) anddensity (g/cm’) in the bourbon whiskey. The alcohol meter can be used enough for determinationof these applications on the bourbon whiskey making process. Technical note: The alcohol sample must be distilled as per the procedure specified on localregulations before the alcohol content can be measured with this alcohol meter. 2. Apparatus 5. Procedure A: Alcohol content (vol%): Take distilled sample solution into beaker Introduce the sampling nozzle into the beaker Press [Meas.] button on the instrument B: Specific gravity (t/t) and Density (g/cm): Take bourbon whiskey sample solution into beaker Introduce the sampling nozzle into the beaker )Press [Meas.] button on the instrument 6. Measurement results Alcohol (vol%) at 20℃ S.G.(t/t) Density (g/cm) 1 36.58 0.95031 0.94861 2 36.57 0.95033 0.94863 3 36.57 0.95033 0.94863 Mean 36.57 0.95032 0.94862 SD 0.01 0.00 0.00 RSD(%) 0.02 0.00 0.00 电 话:021-54488867 电邮:kemu-kem@163.com 网址: http://www. kem-china.com 高精度酒精浓度计测定 波本威士忌的酒精度(英文版) 使用高精度酒精浓度计ALM-155测定波本威士忌中酒精度含量(vol%)、相对密度(t/t)和密度(g/cm3)的应用实例。高精度酒精浓度计ALM-155也可用于酿酒过程中的测量。技术说明: 样品必须按照当地规定的程序蒸馏,然后才能用此高精度酒精浓度计测量乙醇的浓度。
关闭产品配置单
可睦电子(上海)商贸有限公司-日本京都电子(KEM)为您提供《威士忌中酒精度检测方案(饮用酒检测仪)》,该方案主要用于其他酒中理化分析检测,参考标准《暂无》,《威士忌中酒精度检测方案(饮用酒检测仪)》用到的仪器有ALM-155高精度酒精度测定仪(GB 5009.225-2023)、DA-130N手持式数字酒精计/酒精浓度计、DA-130Nc便携式密度计/比重计。
