No.KCA-08001 KEM Application Note No.KCA-08001Coulometric Karl-Fischer titration Kyoto Electronics Manufacturing Co.,Ltd.DataNo.LA47-08130 Moisture of lubricating oil -Summary- Checked the possibility of measuring moisture in lubricating oil by MKC-520 and ADP-513.Consequently, good reproducibility was obtained, but it is considered that measurement wasinfluenced by evaporated component of low boiling point. -Measuring instrument- Main unit:MKC-520 Coulometric KF moisture titratorOption: ADP-513 Evaporator for oil Electrode:M-713 Twin Pt electrode #433-0006Inner burette #433-0006Inner burette -Reagent- Anolyte: Coulomat AG Catholyte: Coulomat CG Carrier gas: Nitrogen -Measurement method- Preparation: (1) Delivered anolyte in titration cell and catholyte in inner burette. (2) Pretitrated for dehydration. (3) Connected MKC-520 and ADP-513, and set the evaporation temperature to 150℃. Measurement: (1) Sample was taken in and measured moisture. -Equation- Moisture(%): ((Data-Drift×t-Blank)/(Wt1-Wt2))×F/10000 Data: Total water content (ug) t : measuring time (s) Wt1: Tare included sample weight (g) Drift: Drift(ug/s) Blank: Blank value (ug) Wt2: Tare included residual weight (g) F=1.00: Factor -Ambient condition- Ambient: 25.3℃ Humidity:61% Weather: Fine 上海旭风科学仪器有限公司上海市闸北区万荣路388弄17号904室200072Http://www. shxf17.com -Measurement parameter- -Printout data- Time Unit Total 00:01:00 57.7 57.7 00:02:00 64.6 122.3 00:03:00 61.8 184.1 00:04:00 0.01 ug/s 51.9 236.0 00:05:00 42.0 277.9 00:06:00 31.0 309.0 00:07:00 24.3 333.2 00:08:00 18.6 351.9 00:09:00 15.3 367.2 00:10100 12.3 379.5 00:11:00 10.2 389.7 00:12:00 8.4 398.1 00:13:00 6.9 404.9 00:14:00 5.7 410.6 00:15:00 5.2 415.8 00:16:00 4.4 420.2 00:17:00 3.8 424.0 00118:00 3.6 427.6 00:19:00 3.3 430.9 00:20:00 3.1 434.0 -Measurement results- Sample size (g) Moisture (ug) Conc.(ppm) Statistics First Second Third 0.21980.2292 0.2261 434.0443.1 433.4 1974.51933.2 1916.9 MeanSD RSD 1941.5 ppm29.690 ppm1.5292% -Comment- It is recommended to reduce sample size and exchange reagent moderately to avoidinterfering sample. Http://www. shxf17.com Tel: Fax: 周峰 zhou-fengcom
关闭产品配置单
上海旭风科学仪器有限公司为您提供《润滑油中水分含量检测方案 》,该方案主要用于润滑油中水分含量检测,参考标准《暂无》,《润滑油中水分含量检测方案 》用到的仪器有null。
