汽车发动机中采用结构化片光照明抑制多重散射-应用与柴油和汽油喷雾的首次评估检测方案(尾气检测)
检测样品
汽车电子电器
检测项目
关联设备
共3种
下载方案
For dense sprays such as those encountered in diesel or gasoline direct injection, the interpretation of spray images
is complicated by the fact that most of the light reaches the detectors after multiple scattering events within the
spray. This may introduce severe errors when extracting quantitative or even qualitative information from these
images as many diagnostics rely on the assumption of single photon scattering.
It has recently been shown that the multiple scattering component of spray images can be effectively suppressed if
sets of structured light sheets are used to illuminate the spray. The aim of this report is to illustrate the potential
and the limitations of this technique for the visualization of sprays from modern diesel and gasoline injectors
at elevated atmospheric pressures. The results clearly show that conventionally recorded images are dominated
by multiple scattering, causing the light sheet to widen substantially and obscuring details within the light sheet
plane. In contrast, multiple scattering and indirect reflections can be suppressed using structured light sheets and
proper image processing. Careful interpretation of the corresponding images reveals details of the inner spray
structure and thus contributes to the understanding of the complicated spray break-up and atomization processes.
北京欧兰科技发展有限公司为您提供《汽车发动机中采用结构化片光照明抑制多重散射-应用与柴油和汽油喷雾的首次评估检测方案(尾气检测)》,该方案主要用于汽车电子电器中采用结构化片光照明抑制多重散射-应用与柴油和汽油喷雾的首次评估检测,参考标准《暂无》,《汽车发动机中采用结构化片光照明抑制多重散射-应用与柴油和汽油喷雾的首次评估检测方案(尾气检测)》用到的仪器有汽车发动机多参量测试系统、LaVision SprayMaster 喷雾成像测量系统、Ekspla CARS 相干反斯托克斯拉曼显微光谱仪。
我要纠错
