室内空气中流动的CFD和PIV研究检测方案(粒子图像测速)
检测样品
空气
检测项目
其他
关联设备
共3种
下载方案
This paper describes the full scale tests for air flows
in a test chamber subject to heat loads generated by
human occupancy and equipment. The Particle Image
Velocimetry (PIV) technique was used to investigate
buoyancy-driven flows near the human thermal
manikin “Victoria”. Based on the experimental
facility details, a full scale 3-D CFD model of the test
facility was generated. The results obtained from the
CFD simulation were compared with data obtained
from the PIV results. Results compare very well and
demonstrate the potential usefulness of PIV as a CFD
validation technique.
北京欧兰科技发展有限公司为您提供《室内空气中流动的CFD和PIV研究检测方案(粒子图像测速)》,该方案主要用于空气中其他检测,参考标准《暂无》,《室内空气中流动的CFD和PIV研究检测方案(粒子图像测速)》用到的仪器有德国LaVision PIV/PLIF粒子成像测速场仪、Imager sCMOS PIV相机、PLIF平面激光诱导荧光火焰燃烧检测系统。
我要纠错
