Acequinocyl 灭螨醒 灭螨醌是拥有萘醌结构的杀螨剂。产生的急性毒性对眼睛、皮肤的刺激性较弱,因此对作业者来说是安全性比较高的农药。但是,它拥有和维生素K相类似的结构,可能会导致凝血能力的降低。(一天吸收的量为 ADI :0.027 mg/kg/day) Acequinocyl. an acaricide having a naphthoquinone structure, shows less irritationagainst skin and eyes, and is considered as a relatively safe pesticide for operators.It is also known to induce hypoactivity of blood clotting. having a similar structure ofvitamin K. (ADI: 0.027 mg/kg/day) .0 0 0:灭螨螨(100pg/mL)Acequinocyl (M.W.384.5) HPLC Conditions ma022 Column : CAPCELL PAK C: MG S5: 2.0 mm i.d.x 150 mm Mobile phase : 1 vol% CH:COOH / CH:OH= 10/ 90 Flow rate : 200 puL/min Temperature :40℃ Detection :PDA 273 nm Inj. vol. :2 pL Sample dssobedin : CH:OH containing 1% CHCOOH ※1 pg/mL=1 ppm
关闭产品配置单
三耀精细化工品销售(北京)有限公司为您提供《灭螨醌中综合分析检测方案(液相色谱柱)》,该方案主要用于杀螨剂中综合分析检测,参考标准《暂无》,《灭螨醌中综合分析检测方案(液相色谱柱)》用到的仪器有null。
