第25卷第2期2004年3月Vol.25 .No. 2Mar. .2004环 境 科 学ENVIRONMENTAL SCIENCE 环 境 科 学25卷52 北京市饮用水中酸盐、卤代乙酸及高氯酸盐研究 刘勇建,牟世芬*,林爱武,崔建华?,杜兵” (1. 中国科学院生态环境研究中心环境化学与生态毒理学重点实验室,北京 100085 , Email :shifenm @mail. rcees. ac. cn; 2.北京市自来水集团有限责任公司水质监测中心,北京 100027) 摘要:调查了北京市饮用水厂源水及出厂水中消毒副产物溴酸盐、卤代乙酸及典型污染物高氯酸盐的污染现状,研究了其来源及环境影响因素.结果表明,北京市饮用水中基本不含溴酸盐;含有5种卤代乙酸和高氯酸盐.饮用水加氯消毒是产生卤代乙酸的主要原因.在所调查水厂出厂水中卤代乙酸的平均浓度为42.1~149.4g/L;其中含氯卤代乙代占总量的90%以上. 5种卤代乙酸的含量顺序为三氯乙酸>二氯乙酸>氯溴乙酸>二溴乙酸>一溴二氯乙酸.饮用水中卤代乙酸受季节影响较大,9月份浓度最高,4月份浓度最低.高氯酸盐主要存在于以地下水为源水的水厂中,受地下水污染影响较大.各水厂出厂水中高氯酸盐含量为0.1~6.8g/L.饮用水中高氯酸盐在11月份含量最高,7月份含量最低. 关键词:饮用水;消毒副产物;溴酸盐;卤代乙酸;高氯酸盐 中图分类号:R123.66文献标识码:A 文章编号:0250-3301(2004)02-0051-05 Investigation of Bromate, Haloacetic Acids and Perchlorate in Beijing’s DrinkingWater L IU Yong-jian, MOU Shifen', LIN Ai-wu, CUIJian hua’, DU Bing’ (1. Research Center for Eco Environmental Sciences , Chinese Academy of Sciences, Beijing 100085, China Email: shifenm @mail.rcees. ac.cn; 2. Water Quality Monitoring Center of Beijing Waterworks Group Limited Company, Beijing 100027 , China) Abstract :Disinfection byproducts and perchlorate in the raw water and finished water of Bejjing s a drinking water plants were investigated. The results indicated that there was little bromate in the drinking water. Five haloacetic acids (HAAs) were found in the wa-ter. The concentrations of the sum of the five HAAs were ranged from 42. 1g/L to 149. g/L. In the HAAs, the chlorine containing HAAs accounted for more than 90 % of the total HAAs.. In the five HAAs, the concentration order of the HAAs weretrichloroacetic acid > dichloroacetic acid > bromochloroacetic acid>dibromoacetic acid> bromodichloroacetic acid. The HAAs inBeijing's drinking water were much influenced by the variation of season. They had the highest concentrations in September and low-est concentration in April , respectively. For perchlorate in Beijings drinking water, it was greatly influenced by the groundwater. Itsconcentrations were between 0. 1~6.8g/L in the finished drinking water. It had peak value in November and minimum value in July, respectively Key words :drinking water; disinfection by products; bromate; haloacetic acids; perchlorate 消毒副产物(Disinfection by-products, DBPs)是指用消毒剂对饮用水消毒时,消毒剂与水中含有的天然有机物反应生成的化合物.由于消毒剂的不同,产生的 DBPs种类较多.但总地来说可分为5类:三卤甲烷、卤代乙酸(Haloacetic acids, HAAs)、卤氧化物、卤代乙腈及直接致诱变化合物[如3-氯-4(二氯甲基)-5-羟基-2(5H)-呋喃等].由于许多 DBPs对人体具有致癌作用1~5],因此对饮用水中溴酸盐、卤代乙酸等的研究成为一个热门领域16~10]. 饮用水中高氯酸盐主要来自火箭、焰火等的固体推进剂中的氧化剂—高氯酸铵11和一些硝酸钾农药1121.由于高氯酸盐可干扰人体甲状腺功能,因此对其在饮用水中的存在、来源及安全阈值的研究引起了环境科学家的重视113,14 国际上对城市市用水中 DBPs 和高氯酸盐均进 行过大规模的调查研究15~191,在充分研究了这些污染物对人体健康危害的基础上规定了饮用水中HAAs、溴酸盐和高氯酸盐的最大容许浓度18,11].而我国对饮用水中 HAAs、溴酸盐的研究较少,调查范围较窄,时限较短[20,21];对饮用水中高氯酸盐的研究基本处于空白阶段[22].因此,出于对人体健康的考虑,本文采集并测定了北京市9个饮用水厂的源水和出厂水样品,调查了饮用水中 DBPs(溴酸盐、9种HAAs)和高氯酸盐的污染现状,研究了其环境影响因素及年变化趋势. ( 收稿日期:2003-03-20;修订日期:2003-05-23 ) ( 基金项目:中国科学院生态环境研究中心知识创新课题 . (RCEES99009) ) ( 作者简介:刘勇建(1975~),男,博士生,主要研究方向为环境分析化学. ) ( *联系人 ) 实验部分 1.1采样点基本情况 于2001-09~2002-07每2个月1次(9月、11月、1月、3月、5月、7月)采集了北京市9个饮用水厂源水及出厂水样品.每次采样均在月初进行.在9个饮用水厂中,A,B,C等3个水厂的源水均为地表水,经加氯消毒等工艺处理后即为出厂水.D,E,F,G, H, I等6个水厂的源水均来自地下水,取水深度约30~40m.由于地下水的采水量有一定限制,因此其出厂水均为水厂自身源水消毒处理后与来自A厂出厂水的直接混合. 1.2 样品的采集、前处理及分析 采集样品时均使用干净的聚四氟乙烯容器,样品采集后应立即进行分析.若不能及时测定,应置于冰箱内于4℃保存,于3天内测定.样品采用离子色谱-电导检测法进行分析,其前处理及具体分析方法参见文献[22,23].所测溴酸盐、9种卤代乙酸及高氯酸盐在饮用水中的检出限和线性范围见表1.由表1可知,目前仅对部分 DBPs(如仅规定了5种HAAs 浓度和的限值)在饮用水中的含量作出了规定,其它化合物对人体健康的影响正在研究中. 表1所测消毒副产物及高氯酸盐种类、容许浓度及检测限/ug·L1 Table 1 The kinds, maximal contamination concentrationsand detection limits of DBPs and perchlorate/pgL 名称 饮用水中最大 检出 线性范 容许浓度[8,11] 限122,23] 围[22,23] 溴酸盐(Bromate) 10/25/10° 0.10 0.3~50 高氯酸盐(Perchlorate) 18 0.20 0.2~100 一氯乙酸(MCAA) 60° 0.37 0.5~100 二氯乙酸(DCAA) 60/50 0.78 1.5~200 三氯乙酸(TCAA) 60/100 1.85 2~200 一溴乙酸(MBAA) 60° 0.58 1~100 二溴乙酸(DBAA) 60° 1.75 2~200 三溴乙酸(TBAA) 9.32 10~500 氯溴乙酸(BCAA) 0.69 1~100 一溴二氯乙酸(BDCAA) 4.07 5~500 一氯二溴乙酸(DBCAA) 5.55 8~500 a:美国EPA标准b :WHO标准c:欧盟标准 d:美国加州卫生部标准 e:美国 EPA 规定饮用水中5种 HAAs (MCAA,DCAA,TCAA,MBAA,DBAA) 浓度和的限值为 6Q g/L. 2 结果与讨论 2.1 饮用水中溴酸盐、卤代乙酸和高氯酸盐的污染现状 北京市饮用水主要采用氯消毒,因此大部分饮 用水厂中均没有溴酸盐检出.在检出溴酸盐的水厂中,其出厂水中溴酸盐浓度较较,平均为0.5~2.2ug/L.在所测9种 HAAs中,有5 种 HAAs(DCAA、TCAA、BCAA、DBAA 和 BDCAA)可被检出,其出厂水中平均浓度分别为8.0~61.qug/L,10.1~78.1ug/L,0.4~38.qug/L, 2.3~22.Qg/L和7.0~46.Qug/L.按表1中美国 EPA 规定的5种 HAAs 总浓度限值,在采样期间,所调查水厂出厂水中仅含有 DCAA、TCAA、DBAA 和3种 HAAs,其浓度和的范围为33.3~120.6ug/L,其中 53.7%的水厂出厂水中上述3种 HAAs 浓度总和超过 60u g/L.从表2可看出,所测水厂中大部分的出厂水中都含有高氯酸盐,其平均浓度在0.2~6.8u g/L之间. 2.2 饮用水中溴酸盐、卤代乙酸和高氯酸盐的来源分析 从表2可知,在A,B,C3个水厂中,源水中溴酸盐沐度均高于出厂水中溴酸盐的浓度.由于这3个水厂源水中基本不含溴离子(检出率10%左右),而溴酸盐是含溴饮用水用臭氧消毒的副产物,因此可判定在消毒过程中并没有溴酸盐生成,这3个水厂中溴酸盐主要来自地表水的污染.对于D和F2个水厂,其出厂水中含有少量的溴酸盐,而源水中没有溴酸盐.D和F是以地下水为源水的水厂,其出厂水有一大部分是来自A厂的出厂水,其中溴酸盐含量受A厂水的影响较大,因此可判定D和F水厂中溴酸盐主要来自受溴酸盐污染的A厂出出水. 从表2可见,所测水厂出厂水中 HAAs 农度均高于相应的源水中 HAAs 的浓度.由此可说明消毒过程中产生了大量的 HAAs.对各饮用水厂水处理过程 HAAs 浓度变化情况研究表明,对源水加氯消毒使得水中 HAAs 浓度从 18.6ug/L增至168.1g/L,增加了8倍左右.虽然经活性炭过滤可去除水中2/3的 HAAs,但为了保证消毒效果而采取的二次加氯措施使得出厂水中 HAAs浓度再次升高.由此可说明加氯消毒是产生 HAAs 的主要原因. 高氯酸盐主要存在于以地下水为源水的水厂中,以地面水为源水的水厂中没有高氯酸盐检出(表2).由此可说明高氯酸盐主要来自地下水源.由于饮用水中高氯酸盐污染源的特殊性,而采样点位于城区,附近没有农药的使用.因此根据国外的研究结果可推测饮用水中高氯酸盐主要来自焰火、炸药等固体推进剂中的氧化剂—高氯酸铵.由于高氯酸铵可在水中溶解,迁移并渗透至地下水层,造成地下水中高氯酸盐的污染. 表222001-09~2002-07所测饮用水厂源水及出厂水中溴酸盐、卤代乙酸及高氯酸盐平均浓度及范围/gL Table 2The average concentrations and ranges of bromate , HAAs and perchlorate in raw water and finishedwater of the investigated drinking water plants from Sept. 2001 to July 2002/gL 2.3 饮用水中溴酸盐、卤代乙酸和高氯酸盐的影响因素及变化趋势 北京市各水厂出厂水中溴酸盐的平均浓度为1.44g/L,远低于美国 EPA 提出的1Qug/L的容许浓度.在此次调查中,溴酸盐仅在部分水厂检出,检出率不高(在6次采样中仅有2次检出溴酸盐,检出率30%左右)且不规律.由于其主要来自外界的污染,影响因素多且难以判断.而北京市饮用水主要采取加氯消毒,因此不存在饮用水中溴酸盐的安全问题. 卤代乙酸是消毒剂与源水中有机物反应生成的产物,源水中有机物的含量、消毒剂的用量及反应温 度等都可影响 HAAs的产生(图1).从图2可看出,7月和9月,随着水温升高,水中微生物活动加剧,分泌的有机物增加,因此水中总有机碳含量也增加.如A厂源水7月份的总有机碳浓度约为 5.2mg/L,而1月份仅为 2.5mg/L.随着生物活动的加剧,为了保证消毒效果,消毒剂的用量也增加.A厂源水7月份的加氯量约为2.0mg/L,高于1月份1.3mg/L的加入量.同时环境温度的升高(7月份水温约为25℃,1月份水温约为1°也有利于 HAAs的生成,因此消毒产生的 HAAs 浓度较高.1月和3月,由于温度的降低,水中微生物活动减少,生成的有机物也减少,消毒剂的用量也相应减小;同时,低温也不利 于 HAAs的生成.因此水中 HAAs 浓度较低. 图1 饮用水消毒过程中 HAAs 浓度变化 Fig. 1 The variation of HAAs during the disinfection 图2 饮用水中 HAAs 季节性变化 Fig. 2 The seasonal variation of HAAs in drinking water 北京市饮用水采用加氯消毒,因此 HAAs 中含氯卤代乙酸浓度较高.从图3可看出,三氯乙酸占总 HAAs量的 43.99%,含氯卤代乙酸占总 HAAs量的90.87%.所测得5种 HAAs 的浓度顺序为TCAA>DCAA>BCAA>DBAA>BDCAA. 二氯乙酸溴氯乙酸二溴乙酸三氯乙酸一溴二氯乙酸 图33各 HAAs占总量的百分比 Fig.3 The percentage of each HAA in the sum of HAAs 溴代乙酸是含溴源水加氯消毒产生的,从表2可知,以地下水为源水的DE入FG、H、I水厂中均含有一定量的溴离子,因此其最终出厂水中也含有一定量的溴代乙酸,其中一溴二氯乙酸的最高浓度达30.9g/L.含溴卤代乙酸占 HAAs 总量的27.16%. 由表2可知,D厂源水和出厂水中高氯酸盐含量最高,因此选取D 厂为代表研究其季节变化趋势.结果表明,11月份源水和出厂水中高氯酸盐含量最高,7月份水中高氯酸盐含量最低(图4).这主要是由于7月份北京市地表水处于丰水期,水量充足,渗入地下水的水量增加,使水中高氯酸盐的含量得到稀释.而11月份处于枯水期,因而水中高氯酸盐含量较高. 图4 D厂源水和出厂水中高氯酸根季节性变化 Fig.4 The seasonal variation of perchlorate in the rawwater and finished water of water plant D 3 结论 对北京市各饮用水厂源水和出厂水的调查研究表明,北京市饮用水中含有5种卤代乙酸和高氯酸盐,基本不含溴酸盐.饮用水中卤代乙酸主要是在加氯消毒过程中产生的,受水中有机物含量、消毒剂用量和水温的影响较大,呈现较强的季节性变化特征.所测卤代乙酸中以含氯卤代乙酸为主, TCAA 和DCAA 的含量占卤代乙酸总量的90%以上.对饮用水中高氯酸盐的研究表明,北京市饮用水中含有一定量的高氯酸盐,且呈现较强的季节性变化特征,地下水源污染是饮用水中高氯酸盐的主要来源. ( 参考文献: ) ( [1] U .S. N C I. Re p ort on th e carcinogenesis bioassay of chloroform (CAS No. 6 7-66-3) T R-000 NTIS Rpt No P B 264018 bethesda[R]. M D: National Cancer I n stitute,1976. ) ( [2] M orris R D, A u det A M, Ang e lillo I F , et al. C h lorination, chlorination by products, and cancer: a m e ta analysis[J ] . Am.J. Public Health, 1992,138 : 492~501. ) ( [3] K urokawa Y , H a yashi Y , Ma e kawa A, e t al. Ca rc inogenicityof potassium bromate a dministered orally to F 334 r ats[J ] . J .Natl. Cancer In s t.,1983 , 7 1: 965~972. ) ( [4] D eangelo A B, M c Millan L P. The carcinogenicity of th e chlori-nated acetic acids [ R]. Cincinnati , Ohio: U SEPA Health Eff e ctResearc h Laboratory, 1 988. ) ( [5] Komulainen H, K osma V M, Vaittinen S L, et al. C a rcino- genicity 0 o 1 f the drinking water mutagen 3-chloro-4 (dichloromethyl)-5hydroxy-2(5H)-furanone i n t h e r a t [J]. J.Natl. Cancer Inst., 1997,89(12):848~856. ) ( [6] N ational P rimary Drinking Water Regulation: I n terim enhanced surface water treatment : Fina l Rule[J]. Fed. R egistr. , 1 996 ,63 ( 241):69477~69521. ) ( [7] Simpson K L , H ayes KD . Drin k ing water disi n fection byprod- ucts: an Australian perspective[J] . Wat . Res. , 1998, 32(5): 1522~1528. ) ( [8] R ichardson S D , Thruston A M, Caughran T V , et a l . D BPs indrinking water[J]. Water. Q ual. T echnol Conf., 1998. ) ( [9] Arora H, Lechevallier M W, Dixon KL. DBP occurrence sur- vey[J]. J . Am. Water Works Assoc . , 1997,89(6):60~68. ) ( [10] Singer P C, O bolensky A, G r einer A . D B Ps in No r th- Carolinadrinking water [J] . J . Am. Water Works A ssoc. , 1995, 87 (10):83~92. ) ( [111 Hantman D P , Munch D J. Det e rmination of perchlorate indrinking w ater using ion c hromatography[R]. Cincinnati, O h i o : USEPA Method 314.0,1999. ) ( [12] Susarla S, Collet t e T W, Garris o n A W, Wolfe N L, Mc- cutcheon S C . Pe r chlorate identification in fertilizers[J] . Envi-ron. Sci . Technol . , 1999,33(19):3469~3472. ) ( [13] Application Note 121. A n alysis of low concentration of perchlo-rate in drinking water and g round w a ter by ion chromatography ) ( [J]. J . Chromatogr. A , 1999,850 : 131~135. ) ( [14] K oester C J, Beller H R , Halden R U . Ana l ysis of perchlorate ingroundwater by e l ectrospary i onization mass s pectrometry/ massspectrometry[J ] . E nviron. Sci. Technol. , 2000, 34 (9):1 8 62~1864. ) ( [15] Nissinen T K, M iettinen I T, Martikainen P J, Vartiainen T. Disinfection by-products in Finnish drinking waters[J]. Chemo- sphere,2002 , 48:9~20. ) ( [16] Lee KJ, Kim B H, Hong J E , Pyo H S , P a rk SJ, Lee D W.A study on the distribution of chlorination by products (CBPs) intreated water i n Korea[J]. Wat. R e s.,20 01 ,35(12 ) :2861 ~ 2872. ) ( [17] Golfinopoulos S K , Nikolaou A D. Di s infection by - products andvolatil e organic compound s i n th e water supply system in Athens, G reece [J]. J . E nviron. S ci. H ealth. A , 2 0 01, 3 6 (4):483~499. ) ( [18] Williams D T,L e Bel G L , B e noit F M . Disinfection byproductsin Canadian d rinking w ater [ J ]. Chemosphere, 1 9 97, 34 ( 2) :299~316. ) ( [19] California Department o f H e alth Services. Perchlorate in C a lifor-nia drinking water [ R]. Updated October,2001. ) ( [20] 侯小平,何成杰,牟世芬.饮用水中消毒副产物及常见阴离子 的离子色谱分析[J].环境化学,1992 ,11 (4) :67~72. ) ( [21] L i S, Zhang XJ , Liu WJ, C ao L L, Wang Z S. F o rmation andevolution of haloacetic acids in drinking water of Beijing city[J].J. Environ. Sci . Health. A, 2001,36( 4 ):475~481. ) ( [22] Liu Y J, Mou S F , H eb e rling S. Det e rmination of tra c e level bromate and p erchlorate in drinking water by ion chromato-graphy w ith a n evaporative preconcentration t echnique [J]. J .Chromatogr . A,2002,956: 8 5~91. ) ( [231 L iu Y J, Mo u S F . Det er mination of trace lev e l of ha l oaceticacids and p erchlorate i n d rinking water b y ion chromatographywith d irect injection[J ] . J . Chromatogr . A, 2003,997:225~ 235. ) ◎Tsinghua Tongfang Optical Disc Co., Ltd. All rights reserved.
关闭还剩3页未读,是否继续阅读?
赛默飞色谱与质谱为您提供《饮用水中无机阴离子检测方案 》,该方案主要用于饮用水中消毒副产物检测,参考标准《暂无》,《饮用水中无机阴离子检测方案 》用到的仪器有null。
