Hitachi High-Technologies Corporation Analysis of Cu in Powdered Soy Bean (Flame Method) KEY WORDS Bio/Medical Science/Food/Pharmaceutical, Food, Fertilizer/Fodder,Food Chemistry, Food Component, Agriculture, Fodder Component, Powdered Soy Bean, Copper, Cu, Flame, AA, ZA3000 Atomic Absorption Photometer(AA) INTRODUCTION: Copper is an essential trace element for living organisms and plays an important role in hematopoiesis and bone metabolism. In the expectation of weight gain effect for livestock and reduction of environmental load by excreted substances, copper in fodder is being analyzed. Copper in soy bean flour certified reference material (INCT-SBF-4)was analyzed.The analysis value obtained was within the range of the certified value and it was confirmed that the procedures from the preparation to the measurement were performed correctly. ZA3000 series instruments employ the polarized zeeman correction method for background corrections even for the flame method. As good baseline stability is provided, copper at a level of about 0.1 mg/L can be sufficiently analyzed. INSTRUMENT CONDITIONS MEASUREMENT PARAMETERS Element : Cu Instrument : ZA3000 Atomization : Flame Wavelength : 324.8 nm Lamp Current : 7.5 mA Slit Width : 1.3nm Atomizer : STD Burner Flame : Air-C2H2Fuel (C2H2) : 2.0 L/min Oxidant (Air) :160 kPa 15.0 L/min Burner Height : 7.5 mm Meas. Mode : Working Curve SignalMode : BKG CorrectedCurve Order : Linear Calculation : Integration Time Constantt:1.0 sec Calculation Time: 5.0 secDelay Time : 5 sec NOTE: [Preparation] 7 mL of nitric acid and 1 mL of hydrogen peroxide solution were added to 0.5 g of the sampleand the mixture was heated for dissolution by a microwave cracking furnace. After cooling,the total volume was made up to 25 mL with purified water. Sample 1: Soy bean flour certified reference material (INCT-SBF-4) Bio/Medical Science/Food/Pharmaceutical, Food, Fertilizer/Fodder, Food Chemistry, Food Component, Agriculture, Fodder Component, Powdered Soy Bean, Copper, Cu, Flame, AA, ZA3000 Sheet Nloo.. / AA120022-00
关闭产品配置单
日立科学仪器(北京)有限公司为您提供《粮食及加工品中营养成分检测方案 》,该方案主要用于豆制品中重金属检测,参考标准《暂无》,《粮食及加工品中营养成分检测方案 》用到的仪器有日立ZA3000系列原子吸收分光光度计。
我要纠错
