Academic's #1 Choice of Syringe Pump, Enhanced for Glucose Clamp Studies! Pump T 11 Elite GCGlucose ClampSyringe Pump Glucose Clamp Harvard Apparatus Method Select GLUCOSE_CLAMP urrent Dose: 15 mg/kg/min O00:00:07 Syringe Select PRESS TO CLEAR MESSAGE Hamilton, 100 ul, 1.457 mm ymellEMe Animal Weight Harvard PW 国30 grams Concentration and Dose Rate 5% 15 mg/kg/min Rate: 9 ul/min Time:00:00:07 Total Volume Dispensed : 951.313nl 5 Han HA Havard EC PumpI1ElHife Intuitive Touch Screenwith Glucose Clamp Software D0 Program Animal Weight, Concentrationand Dose Rate Without a PC 0●●00006Ability to Change Dose Rate While RunningPrevious Dose Rate Displayto Simplify Data Recording HarvardApparafus a division of Harvard Bioscience,Inc. www.harvardapparatus.com Pump111Elite GCGlucose Clamp Infusion System Renowned syringe pump technologyenhanced for academic euglycemic orhyperglycemic glucose clamp studies T'he Pump 11 Elite Glucose Clamp Infusion System is atime saving syringe pump enhancement that offersquick and simple set-up using our innovative touch screendisplay. The built-in software capabilities reduce thepotential for error in your research by providing themost accurate fluid delivery available. Animal Weight, Concentration,and Dose Rate Programming Glucoseclamp method allows for the user toenter a desired concentration, animal weight,and dose rate into the syringe pump. The Pump11 Elite uses that information to properly set theinfusion rate automaticallv. Change Dose Rate While Running In the Glucose Clamp method, the user has theability to change the dose rate during infusion.This allows the execution of complex infusionprocedures without the need to start and stopthe process. Previous Dose Rate Display The previous dose rate setting is displayedwhile the pump is running, which allows foreasy monitoring. When the unit is stopped,the last dose rate set and its duration isclearly displayed. Glucose Clamp Method: Main Setup Screen Last Rate/Duration Glucose Clamp Method: Main Run Screen arvard Apparatus offers a complete Glucose ClampHInfusion System for rats or mice including syringepumps, swivels, tethers and catheters. Multiple syringepumps push glucose, insulin and a drug, tracer glucoseor other fluids into a 3 or 4-way connector whichcombines and reaches the animal via one channel Syringe Pump Ordering Information Order # Product 70-4504GC Pump 11 Elite Infusion/Withdrawal Programmable Single Syringe Pump with Glucose Clamp Method 70-4505GC Pump 11 Elite Infusion/Withdrawal Programmable Dual Syringe Pump with Glucose Clamp Method 70-4506GC Pump 11 Pico Plus Elite Infusion/Withdrawal Programmable Vet Dual Syringe Pump with Glucose Clamp Method 70-4507GC Pump 11 Elite Nanomite Infusion/Withdrawal Programmable Single Syringe Pump with Glucose Clamp Method Typical System for Rat Glucose Clamp Ordering Information Order # Product Various Pump 11 Elite Syringe Pump with Glucose Clamp Method (see syringe pump chart) 61-0003 22 ga Dual Channel Swivel 72-4455 2-Channel VAHD Tether Assembly, 12 in, Sterile 72-4454 2-Channel Rat VAH Harness Injector, Sterile 75-0403 Catheter for Rat Jugular Vein, PU 3Fr, 3.0 cm 75-0404 Catheter for Rat Carotid Artery, PU 1.9-3 Fr, 16.5 cm 75-0220 PinPorts, 22 ga, with Injectors, Sterile 75-0214 Counter-Balanced Lever Arm, 6in, with Holder for 4-Way Connector 75-0212 4-Way X Connector, 22 ga, Sterile of a dual channel swivel. Blood samples are takenmanually or with an automated sampler on the secondchannel. The two-channel VAH simplifies the animalconnection and PinPorts can be used to simplify injectionsor intermittent sampling. Typical System for Mouse Glucose Clamp Ordering Information Order # Product Various Pump11 Elite Syringe Pump with Glucose Clamp Method (see syringe pump chart) 75-0277 Low Torque Dual Channel Swivel, 22 ga OD, 25 ga ID 75-0289 2-Channel Mouse VAH Tether Assembly, 7 in, Sterile 75-0290 2-Channel Mouse VAH Harness, Injector, Sterile 75-0401 Catheter for Mouse Jugular Vein, PU 2 Fr, 10.0 cm 75-0402 Catheter for Mouse Carotid Artery, 1-3 Fr, 8 cm 75-0215 Counter-Balanced Lever Arm, 3.5 in, with Holder for 4-Way Connector 75-0213 4-Way X Connector, 25 ga, Sterile phone 508.893.8999· fax 508.429.5732·email techsupport@harvardapparatus.com www.harvardapparatus.com October Hill Road, Holliston, MA USAphone ·fax email techsupport@harvardapparatus.comwww.harvardapparatus.com ctober Hill Road, Holliston, MA USA
关闭还剩2页未读,是否继续阅读?
继续免费阅读全文香港友诚生物科技有限公司为您提供《葡萄糖钳夹术注射系统》,该方案主要用于其他中null检测,参考标准《暂无》,《葡萄糖钳夹术注射系统》用到的仪器有葡萄糖钳夹注射泵。
