检测样品 其他
检测项目
白金会员
90 篇解决方案
GSThermo Electron SA, Ecublens,Switzerland is ISO certified.Specifications, terms and pricing are subject to change. Not all products are available in all countries. Please consult your local sales representative for details.Part of Thermo Fisher Scientific ApplicationNote:41401 Copper Base ARL 9900 Series with IntelliPowerTMSimultaneous-Sequential XRF Spectrometer Copper alloys Typical performance Key Words Pure copper is mixed with other elements to produce awide range of alloys: ·ARL 9900-33600W ·Brasses (Cu-Zn) ·Bronzes (Cu-Sn) ·Brass ·Bronze Gun metal (Cu-Sn-Zn) used for casting due to itsexcellent fluidity, for valves, taps and water fittings ·Copper ·XRF ·Manganese bronzes (Cu-Zn-Mn) are not true bronzes asSn is not the essential constituent. Used for rudders,propellers and ship fittings ·Cupro-nickel (Cu-Ni) used for coins, tubes, wires,electrical resistances and thermocouples ·Nickel silver (Cu-Ni-Zn) used for marine applications,car radiators and fittings Brasses One the most important non-ferrousengineering alloys. They cover a largerange of physical properties and theirapplications are multiple. Copper is capable of holding about 39 % of zinc in solid solution. Alloys containing less than 39 % Zn are known as a-brasses. This brass (70/30) is very widely employed for cartridge, cases, condensertubes, etc. From 39 % to 46 % of Zn, a B-solid solution gives op-brass. This alloy (60/40) is found in extensive engineering applications with enhanced corrosion resistance used in marine applications. Alloys containing more than 49 % Zn are very hard and only used for brazing brasses. Bronzes Bronzes are used for bearing and gears. There are a widevariety of bronze alloys containing various elements suchas phosphorus, beryllium, silicon,etc.: · Leaded bronzes (Cu-Sn-Pb) are mainly used for bearingsdue to their good wear resistance Aluminum bronzes (Cu-Al) have good corrosionresistance but are difficult to cast. Used for pumps rods,diecastings, etc. (cont. on back page) ·Silicon bronzes (Cu-Sn-Ni) have high electricalconductivity and are used for wires · Phosphor bronzes (Cu-Sn-P) are used for valves,bearings and gears. Cold worked into rods and sheets ELEMENT CONCEN- PRECISION LOD TRATION (1 SIGMA) (3 SIGMA) % % PPM COUNTING TIME 30 s. 30 s. Se Selenium 0.01 0.0004 7 on gonio Si Silicon 0.01 0.0001 8 on gonio 0.05 0.0004 0.1 0.0007 Sn Tin 0.02 0.0002 5 0.5 0.0003 5 0.0014 10 0.002 Te Tellurium 0.01 0.0012 30 on gonio 0.03 0.0015 Zn Zinc 0.2 0.0005 8 1 0.0007 5 0.0015 20 0.008 40 0.011 This list will be updated as improvements are announced. Please contactyour nearest Thermo office for the most recent values. The values listed in the general table are calculatedfrom the following formulae: and BLOD= limit of detection (3 sigma)= 3VQT where Q= counts per second per 1 % element B= background equivalent concentration T= time of analysis in seconds P= the percentage concentration at whichthe sigma value is calculated. The limits of detection are determined with low alloycopper samples. In practice, these values should agree withvalues measured practically using the mathematicalderivation of standard deviation (1 sigma). where the individual readings the arithmetic mean of the individualvalues n= number of determination (normally≥ 10) For guaranteed values, the values of precision and LODs should be multiplied by factor 1.5. Instrument calibration It should be stressed that an XRF spectrometer is a veryaccurate comparator, but the accuracy of the final analysisis entirely dependent on the quality of the standards usedfor calibration. The Thermo Scientific ARL 9900 XRFspectrometer, can be factory calibrated for various copperalloys or a general copper program using commerciallyavailable standards. It can also be calibrated on-site usingwell analyzed samples from the user. Conclusion The long experience of our company in metals analysiscomes from an installed base of over 1'000 XRFspectrometers world-wide. The ARL 9900 is the answer toyour metallurgical analysis needs; whether they beincoming material control, metal QC or productionanalysis. Working 24 hours a day and 7 days a week, theARL 9900 delivers dependable performance year afteryear. The high performance of the ARL 9900 will meetyour analytical needs today and in the future. In addition to these offices, Thermo FisherScientific maintainsa network of represen-tative organizationsthroughout the world. 朗铎投资控股(北京)有限公司全国统一销售电话:400-709-6161全国统一售后电话:400-010-9091 地址:北京市朝阳区高碑店乡西店村1106号源创空间大厦F026室 电话:010-87729275、010-87729285、18513915614传真:010-87729345邮编:100123网址:www.longduoholdings.com电子邮件:sales@longduoholding.com
关闭产品配置单
朗铎科技(北京)有限公司为您提供《Copper BaseARL 9900 Series with IntelliPower? Simultaneous-Sequential XRF Spectrometer》,该方案主要用于其他中null检测,参考标准《暂无》,《Copper BaseARL 9900 Series with IntelliPower? Simultaneous-Sequential XRF Spectrometer》用到的仪器有null。
