当前位置: 其他 > 方案详情
石化产品中金属元素检测方案(能散型XRF)
检测样品 其他
检测项目 金属元素
关联设备 共1种 下载方案
方案详情
No sample preparation. Just collect it and analyze. The unique sample tray ensures proper placement of the sample every time for accurate analysis. The sample tray accommodates both bottles and cups of any size.
泽权仪器ZEAL QUEST EQUIPMENTS X-5000 Portable XRF Analyzer for Petrochemical Elemental Analysis The X-5000 analyzer provides accurate determination of trace to % level of elements in fuels,oils, and lubricants. This powerful field portable analytical instrument is used in a wide variety ofindustries. From identifying elements to determining the actual elemental concentrationspresent in a variety of matrices; solid, powdered, and liquid samples. The analytical performance, closed beam safety and ease of use of traditional bench top XRFunits are all captured in the X-5000. And it delivers true field portability, being packaged into aneasy-to-carry, 22 lb. battery operated XRF with integrated PC and industrialized large touchscreen. The X-5000 sets the benchmark for Performance, Power and Portability. Rivaling its competition with LODS in % the analysis time and compact design 中国(总部) 上海市肇嘉浜路798号坤阳国际商务广场303室(邮编:200032) Key Applications ASTM D4294 Sulfur Analysis Analyze CA, P, Zn, S in Lubricating Oils ● In addition monitor MO, Ba,Mn ● Monitoring Wear Metals Fe,V, Pv, Cr, Cu, Sb, Sn, Mo, Ti, Ni, Cd Heavy Fuel Oil analyzed onboard vessels ● Sulfur content in SOx Emission Control Areas (SECA) ● Diagnose abnormal wear thru the analysis of wear debris and particulates Mercury and Arsenic contamination in 'tank bottoms'sludge No sample preparation. Just collect it and analyze. The unique sample tray ensures proper placement of the sample every time for accurateanalysis. The sample tray accommodates both bottles and cups of any size. The X-5000 is engineered to be used anywhere - in the field, at the production line, in aninspection area. It ensures operator safety as a fully interlocked, closed beam system.The closedbeam, integrated design unique to the X-5000 is a critical safety advancement as portable XRFanalyzers continue to increase in x-ray power and be applied to ever more demanding,in-the-field analytical challenges. Element Detection Limits Element LOD (ppm) (180 s) Phosphorous 30 Cobalt 1 Sulfur 12 Nickel 1 Chlorine 15 Copper 1 Molybdenum 1 Zinc 1 Calcium 5 Mercury 1 Vanadium 1 Arsenic 1 Manganese 1 Lead 1 iron 1 Selenium 1 Key Features and Benefits ● Portable and lightweight ● Fits on any lab bench,at the work site, inspection line, production area上海泽权仪器设备有限公司 ( 中国(总部) 上海市肇嘉浜路798号坤阳国际商务广场303室(邮编:200032) ) ( 直线:0 2 1-62834066 电话:021-62837120/21/62/12 传真:02 1 -62837120/21/62/12-9 http://www.zeal-quest.com ) Sample positioning tray accommodates all sample cups/bottles. No sample preparation required ● No daily calibrations ● Starts up immediately, results are displayed in seconds ● Closed beam operation for user safety Data is stored automatically in tamper-proof format Specifications Concentration Range ppm to % levels Analyzer Weight 10 kg (22 lbs) Measurement Time 180 s Operating Environment -10 to 50°℃ Power Requirements AC or Battery Tube Voltage 10-50kV Tube Current 200 uA User Interface Built in Touchscreen Instrument Dimensions 38x33x28 cm (15x 13 x 11 in.) Sample Chamber 29x11x15 cm (11x6x5 in.) 中国(总部) 上海市肇嘉浜路798号坤阳国际商务广场303室(邮编:200032) 上海泽权仪器设备有限公司直线: 电话: 传真:ttp://www.zeal-quest.com
关闭
  • 1/3
  • 2/3
还剩1页未读,是否继续阅读?
继续免费阅读全文
产品配置单
上海泽权仪器设备有限公司(泽泉国际集团)为您提供《石化产品中金属元素检测方案(能散型XRF)》,该方案主要用于其他中金属元素检测,参考标准《暂无》,《石化产品中金属元素检测方案(能散型XRF)》用到的仪器有奥林巴斯 便携式油品分析仪 X-5000。
我要纠错
推荐专场
相关方案
