硫酸,短链醇中表面特性检测方案
检测样品
其他
检测项目
表面特性
关联设备
共1种
The uptake and reaction of methanol at the air-liquid interface of 0 to 96.5 wt% sulfuric acid (SA) solutions has been observed directly using vibrational sum frequency generation spectroscopy (VSFG) and Raman spectroscopy. Evidence for the formation of methyl hydrogen sulfate (MHS) was obtained by the presence of a new peak in the 800
cm-1 region, not present in either the neat methanol or concentrated sulfuric acid spectra. This peak is attributed to the singly bonded OSO symmetric stretch of MHS. The maximum yield of MHS with a large SA excess (7 SA : 1 methanol) is shown to be (95 ± 5) % at –(15 ± 2) ºC. No evidence was found to suggest formation of dimethyl sulfate.
北京欧兰科技发展有限公司为您提供《硫酸,短链醇中表面特性检测方案 》,该方案主要用于其他中表面特性检测,参考标准《暂无》,《硫酸,短链醇中表面特性检测方案 》用到的仪器有Ekspla SFG 表面和频光谱分析系统。
我要纠错
