通用实验LABCARE 全自动一步法检测人体血清中多氯联苯类物质 Introduction PCBs 能稳定存在于环境中,很容易对人体造成严重的生命危害。即使在1979年被严令禁止进行与 PCBs 相关的生产,之后几十年内仍在人体中检测出极高的含量。 用 SPE(配有多层硅胶柱)处理人体血清中的 PCBs 可以仅仅利用少量的溶剂就可以进行高效、快速的检测。 Instrumentation · FMS, Inc. EconoTrace Q SPE · FMS, Inc. PowerPrepQ Single Column System ·FMS, Inc. SuperVapQ 12 Concentrato · FMS, Inc. SuperVap@ Vial Evaporator· FMS, Inc. 50ml direct to vial concentrator tubes · FMS, Inc. 50ml concentrator tubes (1ml termination) · Thermo Trace Ultra GC with Quantum TSQ ·FMS, Inc. Acidic Silica columns ·Fisher Optima* MeOH · Fisher HPLC grade water ·Fisher Optima* n-Hexane ·Fisher Optima* Methylene Chloride ·Fisher Optima* Formic Acid ·Fisher 6N HCL ·NIST 1958 RM; Fortified Human Serum · Water’s Oasis HLB 500mg, 6ml cartridges · NIST 1958 RM; Fortified Human Serum ·Cambridge Isotopes EC-5366, CDC PCB Calibration Solutions · Cambridge Isotopes EC-5367, CDCMeOH PCB spiking solution · Cambridge Isotopes EC-5321, Multi-Analyte Recovery Standard PCB-123L 106.5 4.1 PCB-128L 103.9 8.1 PCB-138L 90.5 2.6 PCB-153L 87.8 3.5 PCB-156L 90.0 4.6 PCB-157L 92.5 4.1 PCB-167L 83.6 3.5 PCB-170L 87.4 5.8 PCB-178L 84.9 5.0 PCB-180L 78.5 4.0 PCB-189L 80.0 4.1 PCB-194L 70.8 4.9 PCB-206L 61.0 2.0 PCB-209L 53.7 3.3 NIST 1958 的检测结果 NIST NIST UNK NIST NIST UNK Congener Run Ref Mean Congener Run Ref Mean PCB-18 428.755 407 2394.82 PCB-156 404.695 418 13.25 PCB-28 431.89 402 210.44 PCB-157 371.655 420 25.95 PCB-44 449.49 408 846.22 PCB-158 358.76 365 ND PCB-49 321.38 414 17.34 PCB-167 368.91 403 5.24 PCB-52 498.6 401 38.32 PCB-170 390.765 422 33.86 PCB-66 403.64 414 31.21 PCB-172 363.34 395 16.97 PCB-74 422.825 414 26.84 PCB-177 366.41 392 29.37 PCB-87 398.89 396 10.59 PCB-178 369.465 386 6.46 PCB-99 370.27 385 21.90 PCB-180 416.26 459 102.62 PCB-101 399.765 409 20.39 PCB-183 413.855 407 253.61 PCB-105 371.035 419 8.33 PCB-187 384.88 411 4.73 PCB-110 374.53 397 20.18 PCB-189 367.175 402 2.00 PCB-114 42.85 46.6 ND PCB-194 389.49 387 28.05 PCB-118 381.69 412 28.57 PCB-195 377.68 385 ND PCB-123 40.89 52.5 ND PCB-196 401.05 397 ND PCB-128 396.23 420 18.36 PCB-199 388.7 379 ND PCB-138 1098.145 473 206.11 PCB-203 372.38 366 ND PCB-146 381.031 378 14.18 PCB-206 391.555 373 18.47 PCB-149 393.355 373 7.70 PCB-209 349.49 344 10.14 PCB-151 388.47 381 ND PCB-153 445.43 457 126.93 Conclusions NIST 1958年的数据的回收率在 53.7%到106.5%之间,偏差率较低,重现性总体较好。本次实验结果精度较高。在合并重 复实验中,标准偏差率很接近,重现性很高。 利用 FMS的SPE系统可以可以得到高精度、高效率的结果,而无需大量的溶剂与人力。这使得检测人体血液的方法更趋于完善。 AS 器 Labcare Scientific China LimitedTel: ax: -mail: sho@labcaregroup.com Website: http://www.labcarewiki.comISO ISO XVESTOR EN PBOPLK DREGISTEREDFIRM REGISTERIDFIRM Labcare Scientific China LimitedRoom Greenland Inno Intl Plaza, No.GuoDing Road(E),Shanghai, P.R.ChinaTel: ax: -mail: sho@labcaregroup.com Website: http://www.labcarewiki.com器ISO ISO XVESTOK IN PEIPLK DKEGISTERDDFIRM REGISTERIOD FIRM 全自动一步法检测人体血清中多氯联苯类物质 IntroductionPCBs能稳定存在于环境中,很容易对人体造成严重的生命危害。即使在1979年被严令禁止进行与PCBs相关的生产,之后几十年内仍在人体中检测出极高的含量。用SPE(配有多层硅胶柱)处理人体血清中的PCBs可以仅仅利用少量的溶剂就可以进行高效、快速的检测。Instrumentation• FMS, Inc. EconoTrace ® SPE• FMS, Inc. PowerPrep® Single Column System• FMS, Inc. SuperVap® 12 Concentrator• FMS, Inc. SuperVap® Vial Evaporator• FMS, Inc. 50ml direct to vial concentrator tubes• FMS, Inc. 50ml concentrator tubes (1ml termination)• Thermo Trace Ultra GC with Quantum TSQConsumables• FMS, Inc. Acidic Silica columns• Fisher Optima* MeOH• Fisher HPLC grade water• Fisher Optima* n-Hexane• Fisher Optima* Methylene Chloride• Fisher Optima* Formic Acid• Fisher 6N HCL• NIST 1958 RM; Fortified Human Serum• Water’s Oasis HLB 500mg, 6ml cartridges• NIST 1958 RM; Fortified Human Serum• Cambridge Isotopes EC-5366, CDC PCB Calibration Solutions• Cambridge Isotopes EC-5367, CDC MeOH PCB spiking solution• Cambridge Isotopes EC-5321, Multi-Analyte Recovery StandardSample PrepResults 详细结果列表见附件ConclusionsNIST 1958年的数据的回收率在53.7%到106.5%之间,偏差率较低,重现性总体较好。本次实验结果精度较高。在合并重复实验中,标准偏差率很接近,重现性很高。利用FMS的SPE系统可以可以得到高精度、高效率的结果,而无需大量的溶剂与人力。这使得检测人体血液的方法更趋于完善。
关闭还剩1页未读,是否继续阅读?
通用实验科技(中国)有限公司为您提供《人体血清中多氯联苯检测方案(固相萃取仪)》,该方案主要用于全血/血清/血浆中多氯联苯检测,参考标准《暂无》,《人体血清中多氯联苯检测方案(固相萃取仪)》用到的仪器有美国FMS双柱式固相萃取仪TurboTrace ABN、美国多柱样品净化系统FMS-PowerPrep、全自动浓缩与蒸发系统FMS-SuperVap。
