河流沉积物中元素分析检测方案(ICP-AES)
检测样品 土壤
检测项目 (类)金属及其化合物
关联设备 共0种 下载方案
方案详情
The elemental profile of river sediments provides valuable insight into the health of a river, as well as the wider environment. Some elements that are essential for the ecology of the river at trace levels e.g. manganese, copper and zinc, can be toxic at high concentrations. Traditionally, the concentration of elements in river sedi ments is determined via Flame Atomic Absorption Spectroscopy (FAAS). This technique has the drawback of requiring expensive and hazardous gases such as acetylene and nitrous oxide and also requires element - specific sample preparation that adds time and cost to the analysis. The novel Agilent 4200 Microwave Plasma - Atomic Emission Spectrometer (MP - AES) is the ideal alternative for laboratories looking to transition away from FAAS to a higher performance, lower cost and safer technique. MP - AES is a fast sequential, multielement analytical technique that uses a microwave - induced nitrogen - based plasma for sample excitation. The use of nitrogen eliminates the need for acetylene and nitrous oxide, which can
Elemental analysis of riversediment using the Agilent 4200 MP-AES Introduction The elemental profile of river sediments provides valuable insight into thehealth of a river, as well as the wider environment. Some elements that areessential for the ecology of the river at trace levels e. g. manganese,(copperand zinc, can be toxic at high concentrations. Traditionally, the concentration of elements in river sediments is determinedvia Flame Atomic Absorption Spectroscopy (FAAS). This technique has thedrawback of requiring expensive and hazardous gases such as acetyleneand nitrous oxide and also requires element-specific sample preparation thatadds time and cost to the analysis. The novel Agilent 4200 Microwave Plasma-Atomic Emission Spectrometer (MP-AES) is the ideal alternative for laboratories looking to transition away from FAAS to a higher performance, lower cost and safer technique. MP-AES is a fast sequential, multielement analytical technique that uses amicrowave-induced nitrogen-based plasma for sample excitation. The useof nitrogen eliminates the need for acetylene and nitrous oxide,which can Agilent Technologies
关闭
  • 1/1
产品配置单
安捷伦科技(中国)有限公司为您提供《河流沉积物中元素分析检测方案(ICP-AES)》,该方案主要用于土壤中(类)金属及其化合物检测,参考标准《暂无》,《河流沉积物中元素分析检测方案(ICP-AES)》用到的仪器有null。
我要纠错
相关方案
