异丙醇中中痕量元素检测方案(ICP-AES)
检测样品
基础有机原料
检测项目
痕量元素
关联设备
共0种
下载方案
Isopropyl alcoho
l (IPA) is one of the most commonly used organic solvents
in the semiconductor industry. Silicon wafers are dried after surface
cleaning in the manufacturing process and IPA is frequently used during the
drying step. The purity of IPA used is critical since these materials come in
direct contact with the silicon wafers and any contaminants present at this
stage could be detrimental to the overall performance of the final product.
Plasma
based instrument
ation is widely used in the semiconductor industry
due to its multielement capability and sensitivity compared to techniques
such as Flame Atomic Absorption Spectroscopy (FAAS). However a robust
plasma is required for the analysis of organic matrices. M
icrowave Plasma
Atomic Emission Spectroscopy (MP
AES) uses magnetically
coupled
microwave energy to generate a stable plasma that is highly suited to
the analysis of organic solvents. The Agilent 4200 MP
AES features an
advanced microwave cavity and a
torch designed to handle a wide range
of samples, with better detection limits and an increased working range,
compared to FAAS. Major elements (Ca, K, Na and Mg) in IPA can be easily
determined using MP
AES with little sample preparation.
Determination of trace elements inisopropyl alcohol using an Agilent 4200 MP-AESwith External Gas Control Module Introduction Agilent Technologies
关闭
1/1
安捷伦科技(中国)有限公司为您提供《异丙醇中中痕量元素检测方案(ICP-AES)》,该方案主要用于基础有机原料中痕量元素检测,参考标准《暂无》,《异丙醇中中痕量元素检测方案(ICP-AES)》用到的仪器有null。
我要纠错
