水稻中无机砷的高通量检测方案(等离子体质谱)
检测样品
其他粮食加工品
检测项目
无机砷的高通量
关联设备
共0种
下载方案
A fast and sensitive method using hydride generation (HG) with ICP-MS has been developed for the separation and detection of inorganic arsenic (iAs) in foodstuffs. The iAs measured values in 31 commercial rice products all fell below the current legislative maximum level (ML) of 150 μg/kg set by China. Comparing the results obtained by HG-ICP-MS and HPLC-ICP-MS showed comparable limits of detection were achieved. HG-ICP-MS is ideally suited to the large scale screening of food samples, such as rice, as analysis can be performed in a fraction of the time typically required by a conventional HPLC-ICP-MS approach, with no compromise in analytical performance.
安捷伦科技(中国)有限公司为您提供《水稻中无机砷的高通量检测方案(等离子体质谱)》,该方案主要用于其他粮食加工品中无机砷的高通量检测,参考标准《暂无》,《水稻中无机砷的高通量检测方案(等离子体质谱)》用到的仪器有null。
我要纠错
