血清中硒检测方案(原子吸收光谱)
检测样品
全血/血清/血浆
检测项目
硒
关联设备
共1种
下载方案
Trace selenium levels of the order of 20 μg/L are encountered in some neonatal serum samples as a result of selenium deficiency in the mother’s or infant’s diet [9]. Numerous analytical methods [1,5,6,7,9] have been published for the determination of selenium in blood and serum by GFAAS. This study describes the use of new instrumentation and procedures which are important in obtaining the maximum accuracy and precision.
Selenium measurement suffers from a number of difficulties:
? The resonance wavelength of 196.0 nm is in the far UV region where both organic and inorganic compounds, likely to be present in the sample, will exhibit molecular absorption. This can be corrected using Zeeman background correction. Selenium in serum measured by Zeeman graphite furnance atomic absorption spectroscopy Application note Authors John Sanders Agilent Technologies, Melbourne, Australia Clinical research 2 ? The intensity of conventional hollow cathode lamps at this wavelength can cause limitations in the precision [6]. Boosted discharge lamps can increase the intensity of the light source, thus lowering noise levels. Selection of special photomultipliers can assist in providing superior response in this region of the spectrum.
? In this complex sample matrix, selenium may exist in any one of a range of chemical species which create atomization problems in the graphite furnace atomizer. This can be overcome by the use of chemical modifiers.
? Selenium is very volatile and can be lost during the ash stage. Suitable modifiers must be used to form compounds with the selenium and allow higher ash temperatures to remove as much of the matrix as possible before the analyte is atomized.
安捷伦科技(中国)有限公司为您提供《血清中硒检测方案(原子吸收光谱)》,该方案主要用于全血/血清/血浆中硒检测,参考标准《暂无》,《血清中硒检测方案(原子吸收光谱)》用到的仪器有280FS AA 快速序列式火焰原子吸收光谱仪。
我要纠错
